Sub 37 Envelopes not consistent
Posted: Sun May 08, 2016 11:29 am
Hi folks,
Iv'e noticed that the AMP envelope is not consistent and sounds different each time it is triggered. It sounds like sometimes it has a sharp fast attack with a click and other times it is soft and dull, without a sharp attack transient. It's quite noticeable when trying to make a chugging bass arp sound, almost like a type of phasing effect is occurring.
I have triple checked:
All Modulation is set to zero,
EG AMT at zero,
KB TRACK at zero,
GLIDE OFF,
RES & MULTIDRIVE at zero,
FILTER fully open,
Only One OSC engaged,
AMP ENV Settings: ATTACK = 0, DECAY= just under halfway, SUSTAIN = between 1 & 2, RELEASE = approx 2'o'clock
Then if I trigger one note with the ARP or Sequencer using the internal clock or external clock each 7 or so notes have a different attack. It happens even if I trigger the same note manually too. Some are nice, sharp and clicky as I would expect with the ATTACK at zero, but then some are dull and lack the sharp transient - the effect sounds sort of like phasing. Is this expected? Am I possibly overlooking something? Shouldn't it be possible to make each note be triggered in a more consistent fashion? Oh and I tried with different combinations of MULTI TRIG and RESET too - no change.
Any advice greatly appreciated.
EG AMT at zero,
KB TRACK at zero,
GLIDE OFF,
FILTER fully open,
