Hi
Got my brand new Sub 37 from the local Music Store today.
When im programming a new sound and dont touch the Frequency Wheel all keys give back two neutral OSCs except for the second Bb (from the left) - This particular key seems to have another Frequency Rooting which i only can erase when i turn the Frequency Wheel slightly to the left. But then all other Keys are 'out of tune'.
I frankly have to say that i am new to this machine but this problem seems a bit weird. Sounds to me like this particular Bb Key would have another Frequency adjustment as a basis. The other 2 'Bb' keys work fine!
Thanks in advance for any help.
SUB 37 defective key?
Re: SUB 37 defective key?
Sounds like you might need to do a "Note Calibration" procedure on that key. See the NOTE CAL section of the manual (page 48.)
Moose
Moose
Hey! Thank you so much for your hint! This finally worked.
The Department at my local Music Store had no idea and said i have to come back again and replace the Sub 37 with another one (time-consuming ... )
So im really happy over here that this is not needed any more. Still a bit weird that this Note Calibration Problem occurs on a fabric new Instrument. I mean, when you are new to this whole synth topic this particular solution not comes easy to mind. Thanks again.
