From the research I've done on the Minitaur there are probably a couple ways to do that drone: 1) leave to minitar unconnected to the Sub37 and use the Minitaur as a drone, 2) put the Sub37 in duo mode with no note priority on the 2nd VCO so that it becomes the drone and then polychain it to Minitaur to have duophony + drone (in theory that should work but you'd have to try it), or 3) polychain the two and physically play the drone on the left hand.toddmtnbkr wrote:I have question though...will I be able to use the Minitaur as a drone type of oscillator (like OSC 3 on the voyager) or will I only be able to set it up to follow the root note of my Sub37?
How to expand the Sub 37 capabilities even more?
Re: How to expand the Sub 37 capabilities even more?
Max Ferency | http://maxferency.org | max [at] maxferency [dot] org
SYSTEM: macOS & Logic X Pro
GEAR: Matriarch, Sub 37, Korg SV-2, DFAM, MF Drive, MF Delay, MF Boost, Roland RC-202
- Bald Eagle
You could get a Sub Phatty. I believe it will support polychain soon and it's a nice addition even without it. Or get a second Sub 37.
