How to expand the Sub 37 capabilities even more?
Everything Sub.
MaxFerency
Post by MaxFerency » Tue Dec 15, 2015 12:30 pm
I just got my first analogue synth, a Sub 37, and love it. I am already look at way ways to continue to grow my sound producing capabilities by getting more VCO and LFOs to add sound and control to what I can do with the Sub 37. Looking at options like some of moogerfoogers, the CP-251, the Mother-32, and then Werkstatt, its seems to me that the next logical choice for the money to get the best customizability is the Werkstatt. Does that seems right or should it really just be considered for "education" use and not high-level music making? It gives me a VCO, LFO, a lot of CV outs, and the ability yo make custom mods w my basic electronics abilities and at a lower price range than something like the Mother-32 that I can't easily modify.
Max Ferency | http://maxferency.org | max [at] maxferency [dot] org
SYSTEM: macOS & Logic X Pro
GEAR: Sub 37, Korg SV-1, MFB Tanzmaus, Roland RC-202, Sano Zon-Rio Accordion, MF Drive, MF Delay
paul_sub37
Re: How to expand the Sub 37 capabilities even more?
Post by paul_sub37 » Tue Dec 15, 2015 2:11 pm
The first hurdle with the werkstatt is to figure the best way to hook it up with the 37 given the werkstatt's lack of midi and the sub 37s lack of cv out.
If you want Moog and don't need to be able to hack/patch, then the Minitaur may be worth considering in the mix too as that has midi and can be poly-chained with the sub 37:
You can now “Poly Chain” your Minitaur in combination with up to 16 other Moog synths (Little or Slim Phatty; soon to include Sub Phatty and Sub 37 as well). Just send the same MIDI notes to all units, set the Poly Voice Max equal to the total number of synths in the chain, and set each synth to a unique Poly Voice Number. Poly Voice Number = OFF disables poly mode, and is the default setting.
• Program Change Send/Recv: ON by default; you can disable sending or receiving Program Change messages if needed.
My Sub 37 Patches - Sub 37 + Mother 32 + UR-44 + OS X 10.11/Ableton Live/Logic Pro X + Push 2
paramnesia
Post by paramnesia » Tue Dec 15, 2015 2:17 pm
your consumer choices are yours
if you go CV: get a CP-251 & the Moogerfoogers -> feed CP-251 CV out to Sub37 & Moogerfoogers, run audio from Sub37 to Moogerfoogers (or use effects on an aux send/return)
if you go midi: get a Mother32 -> sequence the Mother32 Midi In with the Sub37 Midi Out, run audio from M32 to Sub37 ext audio in
Sub37TE V1.2 / 4 X CP-251, 3 x MF-104M, MF-102, MF-107, MF-108M, 4 x Mother32 + 5 x 104HP Eurorack, Windows 7 - 64 Bit | Ableton Live 9.5 + MaxMSP https://www.modulargrid.net/e/racks/view/458782
MaxFerency
Post by MaxFerency » Tue Dec 15, 2015 3:58 pm
Hmm, thanks to both responses. So it seems like the most overall versitle combination for what I'm thinking of would be a Minitar (or a used Slim Phatty) so I can do either the poly chain or sequence it and feed it back into the Sub37 to be further processed (which I hadn't thought of). I could go the CP-251 & Moogerfoogers route but the price for collecting those would add up fast.
jsharpphoto
Post by jsharpphoto » Thu Dec 17, 2015 9:26 am
I bought two minitaurs soldiers to use as polychain voices for my sub37. When I'm not playing chords, I run them as a bass stereo pair.
Moog Format Modular
Model D (2016)
Moog Subsequent37
Oberheim OB-6
Sequential Rev2
zen4one
Post by zen4one » Thu Dec 17, 2015 11:08 am
jsharpphoto wrote:I bought two minitaurs soldiers to use as polychain voices for my sub37. When I'm not playing chords, I run them as a bass stereo pair.
I thought you actually bought two Minitaurs to show off your awesome woodworking skills?!? The fact that they make fabulous bass was just a bonus :D
You did get me psyched - going to make a set of Zebrawood side panels for my (single) Minitaur over the holidays...
~ Ward ~ zen4one ~
Moog Sub 37, Mother 32, Minitaur, CP-251, MF-102, MF-104M, MF-105M, M-107
Other Akai Advance 49, Beatstep Pro
System Windows 10 Pro, Ableton Live 9.6, Scarlett 6i6, MOTU micro lite
MaxFerency
Post by MaxFerency » Thu Dec 17, 2015 11:10 am
Nice! I love that MF Drive too. I don't ever use my Roland keyboard now without it. Even if I am just using piano sounds with no distortion it gives such a nice warmth to the digital sound.
Ollimac73
Post by Ollimac73 » Fri Dec 18, 2015 7:01 am
I wish I could Polychain it somehow with the SubPhatty :mrgreen: after that a nice pedal (Moog or Strymon BigSky)....
"...A fatal attraction is holding me fast
How can I escape this irresistible grasp?.."
MaxFerency
Post by MaxFerency » Mon Dec 28, 2015 11:12 am
If the Minituars only have a midi in and no midi thru, how do you polychain more than 1 Minitaur? You are getting 3-note polyphony w the two minitaurs and one sub 37, right?
paul_sub37
Post by paul_sub37 » Mon Dec 28, 2015 2:10 pm
Wouldn't a midi-thru box would solve that easily enough eg:
http://www.philrees.co.uk/products/thruunit.htm
paramnesia
Post by paramnesia » Mon Dec 28, 2015 2:31 pm
Midiman Thru 3x8 midi hub
MaxFerency
Post by MaxFerency » Mon Dec 28, 2015 2:36 pm
Ahhh, that makes sense. I wasn't aware of midi thru boxes. From the description on that website it seems like it would be better to use a thru box regardless of if what you are using has thru ports because it prevents delay or data deterioration that can result from too much daisy chaining.
paramnesia
Post by paramnesia » Mon Dec 28, 2015 3:33 pm
this
MaxFerency wrote:...From the description on that website it seems like it would be better to use a thru box regardless of if what you are using has thru ports because it prevents delay or data deterioration that can result from too much daisy chaining.
there's also this with USB for direct DAW integration
http://www.motu.com/products/midi/128
toddmtnbkr
Post by toddmtnbkr » Thu Dec 31, 2015 12:13 am
Wow, didn't know about Midi thru boxes either...and I love the Motu Ultralites I already have...may look into that.
So pumped to see the topic on the forum.
Just got a Minitaur this weekend (while vacationing in Ashville) from the Moog store.
There lead repair tech suggested the Minitaur to add to my Sub 37 as the most effective and useful combination for the Sub37.
I have question though...will I be able to use the Minitaur as a drone type of oscillator (like OSC 3 on the voyager) or will I only be able to set it up to follow the root note of my Sub37?
I'm assuming that I'll be able to run all 4 oscillators slightly detuned (plus the sub OSC) to make a super phat saw base...which is one of the main reasons I snagged the Minitaur.
Another question too, for those that have done this...how to the oscillators and filters compare on the 2?
OS: Windows 7, 64 bit
DAW: Ableton Live 9.6 - Reason 8
Moog: Sub37 - Minitaur - MF Chorus
Interface: Motu Ultralite x 2
Pedals: Stymon BigSky & Dig, Boss DD-7 & RV-3
Other: Roland JU-06
Plugins: Tal-U-No-LX, Kontakt
Ollimac73
Post by Ollimac73 » Thu Dec 31, 2015 9:16 am
I am on the process of selling my SubPhatty + MFB Tanzbar and replace them with a Mother32 + Strymon BigSky....for a better and wider integration with my Sub37.
