Hi!
I've noticed that some factory presets seem to have the LFO1 rate linked to keyboard note (as in: the higher you play, the higher the LFO rate is).
How is this done?
Sub 37 LFO rate linked to keyboard note
- Bald Eagle
Re: Sub 37 LFO rate linked to keyboard note
The LFO KBTRACK parameter in the Controllers menu. Press the Controllers button in the Mod 1 or Mod 2 section and scroll down to that parameter. You can set it up to 200% to control how much the key tracking affects the speed.
Thanks for the answer I'll try as soon as I can!
