Sub 37 Critical Duophonic Feature Request
Posted: Sat Aug 29, 2015 2:09 pm
There's one thing I find a bit frustrating with duophonic mode. Whenever you release the second note, OSC2 goes right back to OSC1 note position. For example, if you press F (OSC1) and C (OSC2) and let go to give it a nice filter release effect, OSC2 will go right back to F instead of sustaining at the position of C.
Is there a way to implement a setting that locks OSC2 to its current position until another note is pressed or if OSC1 is pressed alone a single time as a 'reset' for both OSCs positions. Does that make sense?
Sadly, as it stands, there's no way to have duophonic mode 'releases', OSC2 always goes to OSC1 position when you release.
I believe this is a missed opportunity for duophonic mode. This would greatly enhance the soundscape potential. There should be a way go back to default, but this setting should be an option for duophonic mode.
