Moog Sub 37 - Ratchet
Everything Sub.
Toom
Post by Toom » Sun Aug 23, 2015 10:40 pm
Is there a way to randomize the ratcheting of notes in a sequence? It'd be nice to be able to randomize this every time the sequence is played.
Is this possible?
_DemonDan_
Re: Moog Sub 37 - Ratchet
Post by _DemonDan_ » Mon Aug 24, 2015 9:12 am
Toom wrote:Is there a way to randomize the ratcheting of notes in a sequence? It'd be nice to be able to randomize this every time the sequence is played.
Hi Toom,
RTCH CT (Ratchet Count) is a MOD Destination (pg. 51).
Using one of the MODs, set the SOURCE to Sample & Hold, then set the MOD DEST to PMG.
Now choose RTCH CT as the programmable destination using the CONTROLLERS MENU and turn up the MOD AMT knob.
Toom
Post by Toom » Mon Aug 24, 2015 1:30 pm
But is there a way to randomize which note in the sequence gets the ratchet every time the sequence is repeated?
_DemonDan_
Post by _DemonDan_ » Mon Aug 24, 2015 1:48 pm
Toom wrote:But is there a way to randomize which note in the sequence gets the ratchet every time the sequence is repeated?
Well... to my knowledge, there is no global Ratchet On/Off parameter; each Step has its own Ratchet On/Off switch.
But, when the Ratchet Count is 1, Ratchet is effectively Off.
So you could use a non-sync'd Square Wave LFO to modulate RTCHT CT.
Set MOD DEST to PGM: RTCHT CT and then set the MOD AMT knob to achieve a specific Ratchet Count.
Now it will alternate between a Ratchet Count of 1 and x. Set the LFO to a non-sync'd Rate that's unrelated to the Arp speed and it will act pseudo randomly. Experiment with lots of LFO Rates to find a desired result.
{Don't forget to turn a bunch, or all, of the Steps' Ratchet Counts to ON, or little will happen.}
You could even use your other MOD's LFO RATE destination to modulate the Rate of your Square Wave LFO.
That would create an even better pseudo-random effect.
But, I agree that a global RATCHET ON/OFF destination would be a very useful future parameter to automatically embellish your Arps.
Toom
Post by Toom » Mon Aug 24, 2015 2:35 pm
It works, thanks Dan!
Rbwduece
Post by Rbwduece » Tue Aug 25, 2015 10:29 am
I'm going to have to try this when I get home. Sounds like fun!
ObtuseMoose
Post by ObtuseMoose » Tue Aug 25, 2015 7:58 pm
_DemonDan_ wrote: So you could use a non-sync'd Square Wave LFO to modulate RTCHT CT.
Good grief! What kind of mind does it take to think up something like this? :D Thanks, DemonDan, this is great!
Moose
jsharpphoto
Post by jsharpphoto » Wed Aug 26, 2015 12:54 am
I'm still trying to figure out what Ratchet means. To the manual!
Moog Format Modular
Model D (2016)
Moog Subsequent37
Oberheim OB-6
Sequential Rev2
ramdam
Post by ramdam » Wed Aug 26, 2015 9:15 am
great trick, Dan. all kinds of applications for it.
