Sub 37 Multidrive Problem
Everything Sub.
Chemishev
Post by Chemishev » Thu Jul 23, 2015 8:16 am
Hi guys, I've done two recordings of the issue that I'm having with the Multidrive knob.
Just to explain what's happening - when I twist the Multridrive either physically or automate it by MIDI, I get that noise which I'm not sure if should be there and I'm a little bit annoyed with it. Listen carefully to the noise when the amplitude increases and decreases. I understand the signal goes through the distortion path, but is that noise supposed to be there?
https://soundcloud.com/small-detail/set ... rive-issue
Multidrive MIDI automation
As I'm not sure if this is normal, I urge rest of the Sub 37 owners to test it out themselves and see if they've got the same problem?
Chemishev
Re: Sub 37 Multidrive Problem
Post by Chemishev » Fri Jul 24, 2015 7:07 pm
Anyone, please? I'm seriously considering repairing my Sub 37 while it is still in warranty, if that would be the case.
MRNUTTY
Post by MRNUTTY » Fri Jul 24, 2015 9:38 pm
does it only happpen when you're turning it? perhaps a dirty pot?
Tons of Behringer System 55 clone modules with fixes for design their misses. Good fun!
Rufus the Dog
Post by Rufus the Dog » Sat Jul 25, 2015 3:22 am
I have tried a variety of patches turning the multidrive up and down and hear no issues at all. Grabbing a bit of your sound cloud sample and looking at it in 'Wavepad' you can see little 'spikes' which I think is the noise you are talking about. Are you recording directly from the Sub37?
I can get a similar audible effect if I overdrive my external minifooger delay although there is definitely no clipping in your sample.
R.
Longer sample
Longer sample
Chemishev
Post by Chemishev » Sat Jul 25, 2015 6:53 am
Thanks for you answer, and yes, I'm recording directly from Sub 37 to the UAD Apollo Twin.
Since there's no clipping, I've no idea where that noise comes from..
Does anyone from Moog knows what's happening?
MRNUTTY
Post by MRNUTTY » Sat Jul 25, 2015 9:04 am
When appealing to Moog, it's best to send an email directly to the service department than to hope they're trudging through these forums.
JonLukas
Post by JonLukas » Sat Jul 25, 2015 12:10 pm
I do have a little bit of a click sound when adjusting the Multidrive. I will investigate more and contact Moog as it seems this is not happening to everyone.
Serial number under 200
-Jon
Rufus the Dog
Post by Rufus the Dog » Sun Jul 26, 2015 3:17 am
If I can have your front panel settings or a patch sysex I'll try and see if I can recreate it.. it might be patch dependent
R.
Chemishev
Post by Chemishev » Sun Jul 26, 2015 9:53 am
Rufus the Dog wrote:If I can have your front panel settings or a patch sysex I'll try and see if I can recreate it.. it might be patch dependent
R.
I'm sure it's not patch dependent because I get that noise on each patch that has been saved or it is in the making.. and the weird thing is I've never noticed it before.
I've e-mailed Moog about the issue, let's see what they say
Chemishev
Post by Chemishev » Mon Aug 03, 2015 7:02 am
I got no reply from Moog, messaged them like 10 times probably in the last week. I've got no other option but to return it... thank god I still got 1 month warranty left. this is the second sub 37 that I'm sending back. I feel like buying the 3 years extended warranty option is a necessity for this product. sad.
Moog Music
Post by Moog Music » Mon Aug 03, 2015 3:19 pm
Chemishev wrote:I got no reply from Moog, messaged them like 10 times probably in the last week. I've got no other option but to return it... thank god I still got 1 month warranty left. this is the second sub 37 that I'm sending back. I feel like buying the 3 years extended warranty option is a necessity for this product. sad.
Hi Chemishev,
I'm not sure how your emails could have been missed except that our spam blocker was preventing them from being received. Our apologies for this.
We own an Apollo here as well and tested the issue. Are you by chance plugging into the Hi-Z input? If so, connect to your rear combo jack
The level distorts the JFet in the Hi-Z.
If you are using a DI box or combo jack already, please give us a call directly and we will take care of you - 828-251-0090
-Your Friends at Moog
Chemishev
Post by Chemishev » Mon Aug 03, 2015 7:17 pm
Hi, it could have gone to your spam box because of the link I've included, sorry if that's the case. I'm not using the Hi-Z input nor a DI box, just the rear combo jack. I already got in touch with the UK distributor and we'll hopefully sort it out pretty soon.
