1.1.0 is now here!
Re: 1.1.0 is now here!
Thanks Amos for the update.
I had problems running the auto update - first time through, my S37 'bricked' - when powered on, all LEDS lit, no response from the synth. Then I recalled reading in another thread that the S37 should have a direct USB connection, not via hub.
It was easier to plug direct into a different PC than direct into the one I had previously tried via hub (both PCs running Win 7). This time, the update ran smoothly.
Time for Amos to have a well earned break, but not too long, as I am waiting for the PC editor
Peter
Peter
Have to say my favourite thing so far is the CV mapping. I LOVE being able to use an expression pedal on LFO Rate for starters.
Thank you to Amos and the rest of the Moog crew that worked so hard on this!
For those of you trying to figure out how to use some of the new features, this video helped me tremendously: http://youtu.be/pPwSMW08BNA
Thanks Mike 37 for reply!
Update went smoothly MacOSX 10.7.5.
Very cool update. Really like the CV-mapping additions. The sync of arpeggiator to external Gate is really nice!
Thanx Amos and team!
/Lars
/Lars
- Bald Eagle
Finally had a chance to upgrade. The Windows installer worked perfectly for me using a Windows 8.1 machine.
Thanks to Amos and all of the other hard working folks at Moog. Job well done
And also ...Thanks to all the beta testers.
I noticed a download for 1.1 presets. I installed it but didn't see anything new although I didn't spend much time looking at them. Are there any big changes there?
Chiming in as a Windows 8.1 user who had the upgrade go smoothly. I haven't had time to dig in yet, but I'm really looking forward to it.
Went ok for me, it's like having a new keyboard!
So, not wanting to re-RTFM, has someone compiled a what's new in 1.1.0? Short list:
CV mapping
LFO dest set by knob twiddle
tuning variance
sequencer lights per step / editor
seq ratchet and skip
seq mod only (no notes) mode
What have I missed? Impressive list! I would have been thrilled with just the LFO destination change.
CV mapping
tuning variance
- _DemonDan_
I'm certain that I've missed some but, here are some more:oldmanfury wrote:What have I missed? Impressive list!
Keyboard Transpose
Quick Keyboard Transpose
Tying/Untying Groups of Steps
Adding/Removing Rests
Nondestructively choosing Start/End Steps
Rotating the Pattern
Sequence Send/Recieve via SysEx
Editing Hi/Lo Note in DUO Step
Sequence Mod Amount, Step 1 Reset, Ratchet Count, via CV Mapping
Sequence Step Advance, Sustain Pedal, and Gate Invert for Gate CV Mapping
Single-Note Tuning Change and Bulk Tuning Dump (full 128-note tunings)
Latch Restart
Delay Program Change
Volume Calibration
Send MIDI Start/Stop
Follow Song Position Pointer
Swing!!!
LFOs can Swing!!!
Swing Amount as a Destination
Sequence MOD Destinations
Sequence Page Chase
See Firmware and Panel Version
_ _DemonDan_ _
I'm certain that I've missed some but, here are some more:_DemonDan_ wrote:oldmanfury wrote:What have I missed? Impressive list!
Dang... that's quite a list!
I've tried to update my Sub37 with 1.1.0 firmware updater for Windows and it did not see the MIDI ports. Rebooting the PC and power cycling Sub37 did not help. Tried different Windows PC, same result.
Strangely enough "Moog Sub37" MIDI port was listed, but the software did not see it. Switched updater to advanced mode and explicitly selected MIDI port, still did not work.
Had to resort to manual update procedure which worked seamlessly.
Looks like automatic Sub37 firmware updater needs some work. This was on Windwos 7 and 8.1, embedded USB ports.
/Peter
/Peter
www.midisizer.com - home of MidiALF MIDI/CV step sequencer, MidiREX MIDI Looper and more synth DIY stuff...
Piece of pie! (easy as cake)
Auto Installed using Win7 Pro and and my work laptop using direct USB. Looking forward to sending the EP-3 foot pedals to new exciting destinations. Also curious about the Variance parameter and other features, but a recent gear acquisition came with a 400-page PDF manual, so I'm bogged down with information overload at the moment.
After waiting several days to see if stability issues cropped up (which there were none of apparently) I upgraded my S37 last night using the supplied windows installer. No issues whatsoever with the update and now I'm busy knob-tweaking like never before. Kudos to Amos and Moog!!!
Yeah, the update is fantastic.
Only thing that got broken is the Panel Mode. Quite often, when I switch to Panel Mode, I notice that some parameters aren't what the knob positions are suggesting. Moving the knobs causes a hard jump of the actual parameter value, and then it's correct.
Not dramatic, but it does make the Panel Mode a bit deceptive
___
Sub 37 Cookbook
My Website
Gear List
Me on Instagram
15" late 2013 MacBook Pro
Mac OS X El Capitan 10.11.3
Sub 37 Cookbook
My Website
Gear List
Me on Instagram
jbottrop wrote:Yeah, the update is fantastic.
Try reinitializing the panel mode by pressing that button in and holding it for about 5 seconds.
