Moog Sub 37 Patch Sheet
Ok guys, I hope this works as it should. I made a patch sheet for the Sub 37. It's in A4 format. Print it in B/W and everything should look ok. Hope it's ok with you guys at Moog, I used your artwork The empty MOD-space is intended for notes about internal mod-destinations etc.
Sincerely,
Marten
Re: Moog Sub 37 Patch Sheet
Nicely done. Brings back old school memories!
Great idea Marten, thanks for the work!
I made a higher resolution pdf version but this format isn't allowed, so here is an exported jpg of it. If some of you are interested by the pdf, dont hesitate to pm me
Greg
Greg
- _DemonDan_
Hi Marten and Greg,
What a thoughtful gift to the forum!
A few ideas (I'm a tweaker, forgive me;-)
Move the upper right blank column to next to the Arpeggiator column for the Arp's:
GATE LENGTH
CLOCK DIV
SWING
STEP 1 RESET
END NOTE
as well as forthcoming SEQUENCER parameter values.
Split the blank MOD Notes column into two separate columns for MOD 1 and MOD 2.
Add a section in each EG for:
GATE SOURCE
EXP. ATTACK
CLOCK DIV
Somehow squeeze in a section for:
KB PRIORITY
BEND UP
BEND DOWN
BEND DEST
PRESET VOLUME
But, even if none of that's added, it's still very useful as is.
Thanks Marten! and Greg!
GATE LENGTH
CLOCK DIV
SWING
STEP 1 RESET
END NOTE
GATE SOURCE
EXP. ATTACK
CLOCK DIV
KB PRIORITY
BEND UP
BEND DOWN
BEND DEST
PRESET VOLUME
_ _DemonDan_ _
Demondan,
I don't know if this can be done; as such, I did 'crop and paste' from the Moog pdf, and lamely assembled all the pics into a powerpoint I exported as a pdf, with some touchups to whiten some knobs and pots. Now for text, that will be a tougher job. I'll see what can be done for this.
Does someone can identify the font used by Moog in its manual?
Anyway, thanks for the appreciation, and Marten for the very bright idea I only copied .
Greg
Greg
This is my new version taking into account the wishes of Dan.
Empty column close to Arpeggiator, split Mod empty panel in two for each mod, compressed a bit the envelopes panels so as to be able to squeeze two more writing areas.
I didn't put any texts in these last two, for I don't know what font/police to use to stay coherent and aesthetic with the Moog design.
Anyway, now you have 5 different writing areas to write down all your params .
Best Regards,
Greg
Best Regards,
Greg
Nice! Thank you for doing this.
/Peter
/Peter
www.midisizer.com - home of MidiALF MIDI/CV step sequencer, MidiREX MIDI Looper and more synth DIY stuff...
