Hi bartleby,bartleby wrote:Sequencer: Record Modulation Wheel Position Per Step
I thought I had read that it already does this, but mine doesn't and I can't find it in the manual, so here it is phrased as a feature suggestion: It would be really great if the Sequencer could record the Modulation Wheel position per step.
The ability for the Sub 37's Step Sequencer (in the Arp section) to record two notes, velocity, and Mod Wheel position per step has existed from the very beginning.
The trick is, in order to use the Seq Note, Seq Vel, or Seq Mod as a modulation source, one of them must be chosen as the PGM SRC in the MOD (1 or 2) EDIT menu. The choices are labeled: SEQ NOTE, SEQ VEL, and SEQ MOD.
And... the MOD (1 or 2) SOURCE knob must be set to F.EG/PGM in order to use that choice.
Now it will work exactly as you requested.
