You can already press COMPARE in the middle of the save operation, to scout around for an empty/expendable save location. If you first press SAVE and then COMPARE, the sound you want to save is buffered while you are comparing, so when you exit COMPARE you can finish saving your sound and it will be in the same state you wanted to save before entering COMPARE.BorisYeltsin wrote:WISH LIST FOR SUB 37 FIRMWARE UPDATES:
- When saving patches, I cannot see if the bank/preset saving to already contains a patch. So there's an risk of unwanted overwriting of an existing patch. Is this possible to sort out in a future firmware update?
Yes, we are planning to implement a parameter display on the LCD, so you can see precise values for BPM and other parameters.BorisYeltsin wrote:- Make possible so that BPM and time signature (4/4 etc) shows on screen? Maybe showing for a few seconds when turning the BPM-knob?
- Don't know if this is doable at all, but: The possibility to turn of all the little lights and the screen-light? For me, there are certain settings where this can be useful.
It's not possible to turn the LCD backlight on and off via firmware, and it isn't practical to turn off all the panel LEDs. Sorry about that!
