Controlling Sub Phatty with CV problem!
Everything Sub.
hexeract
Post by hexeract » Thu Jan 30, 2014 11:49 am
The sub phatty controls just fine from a Midi Sequencer. However, when I try to control it with CV, via pitch and gate inputs from a CV sequencer, I run into some major problems.
The phatty plays the notes, transposed off of the last key I pressed on the phattys keyboard. If i press another key, the CV sequence is transposed to that key. I can see this being a useful setting, but I need to know how to shut it off so the Phatty only plays the actual notes coming from the sequencer Can anyone help me?
_DemonDan_
Re: Controlling Sub Phatty with CV problem!
Post by _DemonDan_ » Thu Jan 30, 2014 12:17 pm
The analog Control Voltages from the keyboard and external CV
are being summed before controlling Pitch.
The trick would be to learn which key on that particular model
sends out a voltage closest to (or exactly at) zero.
Then, make sure that's the last key you pressed.
Any deep tweakers know which key that might be for a Sub Phatty?
(I'm not near my gear at the moment.)
hexeract
Post by hexeract » Thu Jan 30, 2014 12:46 pm
I could figure it out by ear, but I hope it doesn't come to that. There's got to be someway to shut it off/bypass it right?
_DemonDan_
Post by _DemonDan_ » Thu Jan 30, 2014 12:53 pm
hexeract wrote:There's got to be someway to shut it off/bypass it right?
I don't think so… But I'm not near it right now.
Obviously, the Local Off is worth exploring, but I suspect that the
last note you played before engaging Local OFF might linger.
So it's worth the effort to find the zero voltage key.
You'll only have to experiment once.
