I'm only getting a response from my sub phatty if it's being used via the AU in Logic. With that I get sound and I can edit it from the plugin but that's as much as I get. None of the controls on the synth have any effect either on the guy of the plugin or the sound coming out of the synth. If I quit Logic I get nothing at all. Not even the keyboard works.
The activate panel button is lit up and the audio is definitely set up correctly as I get a signal if I plug the cable in somewhere else so I'm not sure what I'm doing wrong.
Is there some setting which completely disables the hardware?
No signal from sub phatty
Re: No signal from sub phatty
It sounds like "local control" was turned 'off' somehow -
'local control' needs to be 'on' to use the panel controls & keys.
The manual should give you directions concerning how to reset the 'local control' or do a global settings reset.
Thanks for your reply. Yeah local off has got the synth working so thanks for that but it still doesn't have any effect on the software. If I move a knob on the synth the software stays where it is.
I've tried restarting [computer and synth] but it doesn't change it.
Any ideas?
Any ideas?
Sorted it
For anybody wondering, midi filter was stopping it from working. I set it to 'off' and it worked
Cool - glad you got it all working!
Good catch on the MIDI filtering, BTW...
