Has anyone tried to reproduce the bass sound from the well known bass line from "Chameleon"?
My current setting sounds weak
Do you have better ideas?
osc1 octave: 16'
osc1 wave: square
osc2 and 3 are turned off
Filter cutoff: 50Hz
Filter spacing: 0
Filter resonance: between 3 and 4
Filter keyb cont amount: 0
Filter Attack: 10:30 o'clock
Filter Decay: 1 o'clock
Filter Sustain: 0
Filter Release: 0
Amount to Filter: maximum
Volume Attack: 0
Volume Decay: 2 o'clock
Volume Sustain: 0
Volume Release: 0
Bass Sound from the Head Hunters' Chameleon
http://www.psicolor.de
Yes, Herbie did use an Oddy, but only the earlier white-faced Oddys had a 12dB filter (a few black-gold ones did too).bunnyman wrote:That's a good sound, but didn't Herbie use an ARP Odyssey in Headhunters? Maybe try setting the filters to 2 pole?
- CM
Akai Miniak, Moog Sub 37 on pre-order, Roland Jupiter-4, Roland SH-101, Sequential Circuits Prophet-600, iPad, NI Komplete
Re: Thread Topic
Hello,
One thing you may want to consider in programming a patch based on the ARP Odyssey is that the envelopes on the Oddy are a bit slower
than the Mini's were.
The Mini's attack segment was about 1mS. The Oddy's was spec'd @ about 5mS, so you may want to slow down that segment on the amplifier envelope.
Another thing is, one of the envelope generators on the Oddy is only
two-segment (AR).
If the patch you're programming doesn't use this, and instead uses the ADSR (for filter and amplifier), the envelope settings on the Vger can be set to the
same value, duplicating the single ADSR on the Odyssey.
Regards,
lawrence
two-segment (AR).
Regards,
lawrence
Re: Bass Sound from the Head Hunters' Chameleon
(Resurrecting an old thread here...) This video shows someone who programmed a decent Chameleon bass on a Moog Prodigy. The patch settings are shown at the end of the video. I'm going to try this with my Slim Phatty and see how it goes.
http://www.youtube.com/watch?v=nQnzaiADEpA
Phurniture wrote:(Resurrecting an old thread here...) This video shows someone who programmed a decent Chameleon bass on a Moog Prodigy. The patch settings are shown at the end of the video. I'm going to try this with my Slim Phatty and see how it goes.
Hi Phurniture -
About the Chameleon patch - we held a Little Phatty patch contest on KnobTweak a few years ago and I recall that member Control_Voltage submitted a pretty good version of that patch in the 'Basses' category. You might want to check it out to see how it compares to yours:
KnobTweak > Files > Little Phatty > LP Programmer's Challenge > Basses
- Greg
As someone wrote above, with the Pro-one you can patch that chameleon bass sound very good, I´ve done it without any extra gear. But on my Voyager OS it´s hard....the filter is in my opinion not as "agressive", the Pro-one is better in this matter.
