end.
alainhubert
end.
Post by alainhubert » Fri Mar 20, 2009 12:22 am
end.
acorkos
Post by acorkos » Fri Mar 20, 2009 1:56 am
my OS #243 crapped out 3 weeks after i got it home with the keyscan board failure. moog shipped me a replacement board directly (took a week to get to me) and i installed it and was back in business in 20 minutes. an easy fix.
Post by EricK » Fri Mar 20, 2009 9:08 am
That IS the keyboard scanner. Just email amos and he will probabvly send you one. I don't know about the OS, but for the Select Its just a matter of unscrewing about 15 screws. Youll have to unscrew the LCH panel and disconnect 2 of those wires. THen youll have to turn the Voyager upside down, unscrew the bottom, remove the keyboard, uynscrew the scanner and then replace it with a new board. Then do everthing in reverse and your OS willbe brand new.
But yeah, the Oscs playing at a low voltage....thats because they are receiving the lowest possible voltage from the keyboard.
Amos will provide you with more detailed instructions and your Voyager will survive the surgery without any scars.
You shouldn't have to ship your voyager anywhere, but since yours is an OS I don't know what they might tell you.
Shoudl be a very quick fix though.
Voltor07
Post by Voltor07 » Fri Mar 20, 2009 12:44 pm
Geez, EricK, make it sound like brain surgery, why don't you? :lol:
Sub 37 #000068, Minitaur, CP-251, MF-102&103, EHX #1 Echo, EHX Space Drums/Crash Pads, QSC GX-3, Miracle Pianos, Walking Stick ribbon controller, Synthutron.com, 1983 Hammond organ.
Pogo
Post by Pogo » Fri Mar 20, 2009 1:01 pm
can you share the patch with us ?
Jrayk Roze
Post by Jrayk Roze » Fri Mar 20, 2009 5:25 pm
This seems to be a common problem with the OS.
Mine crapped out 4 days after I got it :(
Voyager Old School #0005, Etherwave #18321, Stereo Memory Man w/ Hazarai, CP-251, and a Nord Lead 2X
acorkos
Post by acorkos » Fri Mar 20, 2009 5:29 pm
the OS has 8 screws that hold the keybed in place that need to be removed, along with 2 screws holding the pitch/mod wheel assembly.
once you get the keybed up (the keyscan board is underneath it), 4 more screws hold the keyscan board in place.
it's pretty straightforward and simple.
Voltor07
Post by Voltor07 » Fri Mar 20, 2009 5:51 pm
acorkos wrote:the OS has 8 screws that hold the keybed in place that need to be removed, along with 2 screws holding the pitch/mod wheel assembly.
Much better than EricK's description. :lol:
wooperman
Post by wooperman » Fri Mar 20, 2009 6:00 pm
Are Voyaer OS keyboards dropping like flies? Do I need to keep a backup keyscan on hand or is this a common part? If I go Rip Van Winkle I might wake up in a world that has no keyscan parts, and that just won't do.
Pogo
Post by Pogo » Fri Mar 20, 2009 7:07 pm
yea what gives ? are the performers more sturdy ? or are you guys just having some plain old bad luck ?
acorkos
Post by acorkos » Fri Mar 20, 2009 8:24 pm
too much chinese melamine in the PCB..... :shock:
Post by EricK » Fri Mar 20, 2009 9:26 pm
Amos asked me what the serial number was.
I think Amos told me something like this on the phone:
"We produced a run of Voyagers that had some bad keyscaners. Im going to send you another one that has been reprogrammed so it won't fail after that." After that particular run of Voyagers, they fixed the problem.
He sent me the piece and I mailed him back the other one.
Easy as pie.
The Real Amos might get on here and give you a more accurate reason than the one that I pulled from my memory banks.
Voltor07
Post by Voltor07 » Fri Mar 20, 2009 10:45 pm
acorkos wrote:too much chinese melamine in the PCB..... :shock:
Yeah, it's definitely not the lead in the Chinese solder or the Chinese asbestos the PCB is made of. :lol:
wooperman
Post by wooperman » Sat Mar 21, 2009 11:39 am
Voltor,
Shhh!!!!! Those are ancient chinese secrets. (Carcinogens make it look, taste, feel, smell, work better) :x
Pogo
Post by Pogo » Sat Mar 21, 2009 2:04 pm
Ehhh .... What ? Bad batch ? What is your serial ? I don't want any part of that
