VOYAGERS, KEYBOARD STANDS & 2ND TIER PHOBIA!!!
Keyboard Komuso
Post by Keyboard Komuso » Fri May 23, 2008 10:16 am
With the newest arrival to my studio, A Prophet 08, I am encountering space issues. It's a fantastic sounding board, really compliments my Voyager beautifully! The 2 belong together. However, I am having a really hard time putting my Voyager on the second tier of my keyboard stand. It is a heavy beast! Putting it on the first level is not an option as I can't tilt the control panel up due to space restrictions with my stand and when left flat, half the panel is hidden under the 2nd tier, even at full height. The Prophet, being much thinner and narrow works better on the bottom. So do any of you Moogers keep your beloved Voyagers on the second level? Any fears of coming home to a Moog on the floor? My stand is rated for 75 lbs on the second tier, but it seems to wobble quite a bit while playing.
"Music is the space between the notes." - Claude Debussy
http://www.kieranshannon.com
Moog LP Stage 2, DSI Prophet 08, Korg Radias, Korg SV-1, Kurzweil PC1X
Marzzz
Post by Marzzz » Fri May 23, 2008 10:41 am
I use a Quiklok Z-726 stand, with my Voyager on top of an Andromeda. It works great and has been very stable. You will always get some wobble on the top tier, there really is no way to avoid it short of having a welded (but completely unadjustable) stand.
Keyboard Komuso
Post by Keyboard Komuso » Fri May 23, 2008 10:51 am
That's exactly the stand I have. Reassuring to know your using the same one with good results.
gd
Post by gd » Fri May 23, 2008 12:16 pm
it should be fine, I have mine on the 3rd tier of my stand and it has been fine for the last 3 years.
http://www.quiklok.com/catalog/?p=produ ... ame=QL-623
Mini D, P'08 ..
jwolford
Post by jwolford » Fri May 23, 2008 2:05 pm
I got this one:
http://www.musiciansfriend.com/product/ ... sku=450389
It's nice, but I was not comfortable with the Voyager on the top, plus I mostly work seated in the studio. I ended up removing the second tier and moving the Voyager to the 1st tier. Not the solution I was hoping for. But I like having the voyager at a seated working height with the panel fully upright. This means I can not use the second tier. The fully extended panel would get in the way of a keyboard on the second tier.
I talked to the shop I bought it from, who recommended drilling holses in the second tier arms so I could raise it higher. But again, I am not comfortable with placing a keyboard on a "hacked tier" directly above the Voyager.
I've been to post here for a while to ask what others are using.
Keyboard Komuso
Post by Keyboard Komuso » Fri May 23, 2008 3:05 pm
Yes, I can relate. I'm not too keen on the idea of the Voyager on the 2nd tier either. My lack of faith in stands started when a 2 tier x-frame holding my Trinity and MS2000 came crashing down! The MS landing on top of the Trinity. I never used an X frame again. I much prefer Z style stands. I have a single Z frame and was thinking of getting another and setting it higher and some how sliding it's legs inderneath the first creating a super solid 2 tier of sorts (did that make sense to anyone?)
Post by EricK » Sat May 24, 2008 2:00 am
Thats a very nicely designed website. Im going to bookmark it.
cageswood
Post by cageswood » Sun May 25, 2008 12:54 am
I have an Ultimate stand and the Voyager sits nicely on the very top with no problem
c7sus
Post by c7sus » Mon May 26, 2008 12:22 am
Second the Ultimate. My EB lives downstairs from the U-20. The support arm makes a nice support for the Littlelite. :wink:
Demokid
Post by Demokid » Wed May 28, 2008 9:49 am
I just bought two stands from Jaspers a Keyboard Rack 170-4-145B and a Keyboard Rack 170-4-120B. They are great!
http://www.jaspers-alu.de/eng/index.html
Kind regards
Demokid
Gearlist: Andromeda A6, Emu E4XT Ultra, Korg MS20, Minimoog Model D (incl.MIDI), Minimoog Voyager AE, Roland Jupiter-8 (MIDI), RE-301, Prophet~5 (Rev3.3 incl MIDI), Poly Evolver Keyboard, Pro~One, Prophet 08, Synthesizers.com Custom Studio-44
Keyboard Komuso
Post by Keyboard Komuso » Wed May 28, 2008 3:13 pm
Thanks EricK for the compliments on my site, and to all for the stand info. Hearing that others use the 2nd tier puts my mind at ease. I have a very solid QuickLok. I think I'm just gonna go for it.
ikazlar
Post by ikazlar » Sun Jun 01, 2008 11:06 am
I do have a Quik Lok, which I don't trust that much - Voyager is on the second tier and it wiggles a bit. :shock: For maximum stability check this out:
Made of iron, it weighs a ton, but it can also carry a ton :D Maybe, I need to build myself another one..
