My VOS is due to arrive tomorrow (yay!) and I have a new VX-351 sitting on a table here waiting for it. I just wanted to check: do the same instructions for installation of the internal card apply for the VOS?
I'm assuming so, but before I open her up...
Voyager Old School / VX-351
- Doc Tonewheel
They don't connect to anything - the X, Y, A and Gate jacks are not used when a VX-351 is connected to the Voyager Old School. All of the other jacks are functional and operate as you would expect. Note, however, that a couple of the panel labels won't be correct when a VX-351 is connected to the Old School:Doc Tonewheel wrote:Thanks, I'm in the same position. What do the Touch Surface X, Y, A, and Gate on the VX connect to since there is no touch plate on the Old School?
VX-351/Busses/Wheel = Old School Mod 1 Bus Output
Vx-351/Busses/Pedal = Old School Mod 2 Bus Output
This is described in the User's Manual.
Ill bet they could remedy that problem if they made an independant touchpad like Big Briar used to. If they did that Id surely want the OS.Doc Tonewheel wrote:Thanks, I'm in the same position. What do the Touch Surface X, Y, A, and Gate on the VX connect to since there is no touch plate on the Old School?
- Doc Tonewheel
Re: Voyager Old School / VX-351
Reviving this old thread first to say that I just got my VX-351 and so, following directions, opened my Old School to put the adapter on only to find out that the lid wouldn't close on the back of the analog board !!!
Searched far and wide to see what I did wrong, for an addendum for perhaps the higher serial #'s of Old Schools, considered moving what looked like additional screw holes of the analog board, etc.
Luckily this post told me that the adapter isn't required for the OS !!! Who knew !! Did I miss the fine print or the bold warning note (I've done so before!).
The other part of this post is to ask if there is anyway to boost the voltage or define a minimum voltage or offset? If the Attenuator rolls back some voltage, is there a way to set the minimum to say, .25 V or .5V? In this case, I'm keen to patch VEL into Volume CV in on the OS for touch sensitivity tied to Volume. It does work but 1/2 the time I just get clicks because it's just a bit too low.
Thanks.
-Mike W. from NJ
Thanks.
-Mike W. from NJ
