Moog Music Forum
Share Ideas and Pass the word
Voyager 3.0 Upgrade digi board
Postby StefanH » Sun Mar 11, 2007 4:26 pm
to my shame i own the board since month, but didn't build it in since now.
Today i wanted to start and took the Manual for the upgrade, but than i realised that the board on the picture looks totaly diffrent to mine. Ok, maybe i should open my voyager first and should have a look, but the board in the manula is much bibber than mine. If you have a look, you can see that board is screwed up with three srews on the length, mine have only two, also the plugs are in an other order. Mybe i should give itt a try and open it, but i am bit afraid, that some of the cables are to short or something like that.
It is a REV4 board. Are there diffrent layouts of the board? Is it ok like that?
Pleas3e, give me a tip, if yes, i will start to build it in...
Stefan
StefanH
Postby till » Sun Mar 11, 2007 5:17 pm
The so called 3.0 hardware upgrade include a newer digital board version. It is not build like the old board.
The old digital board had pins (of the electric components) inserted through holes of the board and then soldered from the other side. But this is now not the way boards are build. I think this is also due to the bann of lead for soldering.
So newer boards, not only found inside the Voyager, have so called SMD compnents. These are not pushed through drilled holes of the board, but somehow soldered on top of the board traces.
So just follow the original Moog instructions. And don't mind the board being a bit smaller.
Have a look here for comaprision:
old board:
new board:
I hope this helps you.
Sequence:
Prodigy * Minimoog (1979) * Voyager * MF102 * MF103 * MF104z * MP201 * Taurus 3 * Minitaur * Sub Phatty * MF105 * Minimoog reissues with MUSEs * One
till
Postby StefanH » Sun Mar 11, 2007 7:23 pm
Thanks Till,
this was exactly the information i was hoping for. As i can see,also the cables are long enough...
Thanks,
Stefan
StefanH
Postby electrical_engineer_gEEk » Mon Mar 12, 2007 10:30 am
Thanks for taking time to post those pictures...really interesting!
What about the VR1 trimmer on the new digital SMD PCB?
Postby MartijnTS » Tue Apr 03, 2007 4:16 am
The 3.0 hardware upgrade manual describes the +/- 1.6 Volt callibration procedure after installing the board by turning a trimmer called VR1.
The new small digital board doesn't have VR1. What to do?!
MartijnTS
Postby Markyboard » Fri Apr 20, 2007 7:32 pm
I opened my Voyager for the first time to install the VX-351 adapter. I have the old (long) board. And....I had the 3.0 hardware update. So I guess that they modified the board with more RAM. A hell of a lot cheaper for Moog I assume even though I was charged the same price. Oh well. It will be a lot easier to replace a component if I ever need to with the thru hole mounting as opposed to the surface mount.
Markyboard
Postby till » Sat Apr 21, 2007 5:34 am
Markyboard,
on the other hand, the production of through hole components will stop most likely in the next years. If there are no through hole components being used by manufactures (due to the leed free soldering rules), then there is no big market for the old components anymore. And the manufactures don't care for so few synth freaks.
Sequence:
till
Postby Markyboard » Sat Apr 21, 2007 7:10 am
I didn't look but I assume these are common off the shelf parts. Having repaired my Memorymoog recently and stocking up on ICs I suspect there will be a supply of dual in line parts around for quite some time. Of course there are certain parts that are difficult if not impossible to get (CEMs).
Markyboard
Re: Voyager 3.0 Upgrade digi board
Postby reekster » Sun Oct 02, 2016 6:45 pm
Thank you for this post. It's now 2016 and I got a replacement board only to be horrified that it looks different!
reekster
Postby reekster » Tue Jul 17, 2018 11:24 pm
I put the smaller board in my 50th Anniversary Voyager and it fits fine. I was surprised as you were but all the cables reach and the mounting holes so it’s all great. My Voyager has been working great.
reekster
Return to Minimoog Forum
Who is online
Users browsing this forum: CommonCrawl [Bot] and 2 guests
