Wah pedal with Voyager
Has anyone tried it?What's the outcome?Is it worth the idea?
Re: Post Subject
Hello,
Using a wah pedal on a monosynth is something many artists have done for some time. I find they tend to be of best use on monosynths that are limited to lowpass filtering. Many classic solos are Minimoog D with one of these pedals. As an reference, check out George Duke's solo at the end of the Stanley Clarke track "Journey to Love".
In the case of the Vger, I find them to be redundant. Most classic wah effects (Crybaby, Morley, etc) are essentially a manually swept bandpass filter (with a high Q).
The Vger has a bandpass filtering mode. By using various output
configs with or without a shorting plug, in conjunction with the filter spacing,
resonance, manual cutoff freq settings, then assigning them to the pedal bus, a wide range of wah effects can be produced.
Regards,
Lawrence
Regards,
Lawrence
or i could just google it.....
if anyone wants some in-depth info, look no further:
http://www.geofex.com/Article_Folders/w ... wahped.htm
