Reissue Model D Midi issue
jsharpphoto
Post by jsharpphoto » Fri Aug 23, 2019 11:05 pm
I'm pulling my hair out.
I have a reissue model D. My ideal setup would be:
Synth with local control off > midi out into Ableton live > Ableton midi track using the model D as a keyboard/midi to the model D > audio from synth to my interface.
The reasoning for treating the keyboard and synth separately, is to use Ableton's arpeggiator/midi scales/etc and to record midi clips. I know I can record midi clips without turning local control off, but using the midi arpeggiator with local turned on creates a less than desirable real-time experience.
Here's where things are hanging up.
With local control off - I can record a clip but not hear the synth. If I play the clip back, I CAN hear the synth. So I know that the midi connections are correct, or it wouldn't properly record or playback. IT JUST ISN"T SENDING THROUGH IN REAL TIME. and I can't hear the synth while I record. It's madness.
I even tried to bypass Ableton all together, and just connect the midi out of the synth to the midi input of the synth, and I get no sound.
So what I can tell is that with local control off, it's somehow cancelling out the incoming midi signal.
To recap. With local control off, I can record midi from the keyboard, and send midi to the synth, but I can't do both at the same time?
I am up to date on firmware.
Moog Format Modular
Model D (2016)
Moog MG-1
Access Virus Ti2 Polar
Oberheim OB-6
Sequential Rev2
Minimooger
Re: Reissue Model D Midi issue
Post by Minimooger » Thu Sep 12, 2019 11:02 am
that does not work because the local off implementation in the mini reissue is fishy . however there are modifications on the market which do a great leapfrog in terms of midi for the mini .
