Hi forum,
Looking for some help...I bought a Voyager, then flashed the latest OS to it. It took quite a few attempts to do this.
Now the Voyager is very unstable, reboots frequently, sometimes just freezes and showing a blank display. If I'm lucky it works for a day or two, but sometimes it can reboot several times per minute.
Feels very shaky, could all this be from a badly flashed OS or what do you think? I've reflashed two more times but it shows the same behavior. Could the flash memory be damaged or is perhaps a digital board swap to be the best way out of this mess?
I need my Moog basses!
cheers /Martin
Voyager RME issue
Re: Voyager RME issue
What happens if you use os 3.5 instead of 3.6 and did it work properly before you flashed it ?
Hi, I’m a new Voyager user too.
I don’t know exactly if it comes from the OS or not. Did this start only after you’ve updated your Voyager or was it something present before, even if not as bad?
It’s important to know this, and the reason is quite simple: maybe it wasn’t functional even before the update. There’s a topic here where Rudi Linnhart explains how to turn on the Voyager in a basic mode so you can flash the OS again, maybe it would work for you.
I’m not exactly sure if these symptoms are OS related, but I do know that restarting to Voyager several times in a row might cause some damage. I’d contact Moog Music. They’re great!
Cheers!
Cheers!
Moog Minimoog Voyager Performer Edition and Little Phatty Stage II | Elektron Analog Four and Analog Rytm | Mutable Instruments Ambika | Korg Minilogue
Check the power supply. If it is causing spikes and ditches now and then, problems like described might happen.
Sequence:
Sequence:
Thanks for your suggestions. I did try reflashing v3.5 but since it so often fails, I might want to try that again.
I'll also check for spikes in the power supply.
I checked what a new digital board would cost here in Sweden, and it was a small fortune, so I can't just replace that one.
I'll get back with new findings when I've done more trials.
cheers
Martin
cheers
Martin
do you remember where the thread is to start Voyager in basic mode? I am told the symptoms are a dead digital board but wondering if the o.s. just needs a reset. Currently nothing shows on screen, boots with correct led sequence but little sound and no readout.
IgorCristo wrote:Hi, I’m a new Voyager user too.
Cheers!
Hi, just wanted to say that the problem has been found and resolved...It was a connector to the power supply that was glitchy and sometimes caused a short power failure that caused the Voyager to reboot. I got it fixed by Rudi in Germany when he did the Slew rate modification to it, so I'm a happy man now Cheers friends!
Good to hear about the Voyager RME fixed locally. And the Slew Rate Modification is a must-have to me. So did you meet Rudi in person or did you ship the RME by postal service? Rudi is such a friendly person!
rudefelt wrote:Hi, just wanted to say that the problem has been found and resolved...It was a connector to the power supply that was glitchy and sometimes caused a short power failure that caused the Voyager to reboot. I got it fixed by Rudi in Germany when he did the Slew rate modification to it, so I'm a happy man now Cheers friends!
Sequence:
Sequence:
Hi Till, I didn't meet Rudi in person but we had a long and fruitful email conversation. He was very patient with me.till wrote:Good to hear about the Voyager RME fixed locally. And the Slew Rate Modification is a must-have to me. So did you meet Rudi in person or did you ship the RME by postal service? Rudi is such a friendly person!
Will you be at the Superbooth in Berlin this May? I will be there.rudefelt wrote:Hi Till, I didn't meet Rudi in person but we had a long and fruitful email conversation. He was very patient with me.till wrote:Good to hear about the Voyager RME fixed locally. And the Slew Rate Modification is a must-have to me. So did you meet Rudi in person or did you ship the RME by postal service? Rudi is such a friendly person!
Sequence:
Sequence:
