I am using the stereo outs on my voyager, and the dual filter "spacing" adj to sweep
if I make a TRS connector for the voyager mixer out/filter in, can I also split that signal off, with a Y cable, into other FX pedals etc for a separate audio signal? and feed the unprocessed voyager signal back into the "ext in" audio, to get the minimoog self-driven overdrive?
ie: I will take a feed thru external pedals, and run that into another audio input for my DAW
ch 1 = left voyager ( including mixer in )
ch 2 = right voyager ( including mixer in )
ch 3 = external pedal audio loop
I want to use the mixer in as an overdrive, feeding the voyager into itself without the external signal processing. but also run the 3rd audio signal thru some FX
thx!
voyager mixer out/filter in Q
Re: voyager mixer out/filter in Q
Yep! The technique is well-described in a few KnobTweak articles. Look in the Files/Voyager section for:
Kicking It Up.zip
Also, you might take a look at these related articles:
Old Dog, New Tricks.zip
Mix Out Insert Cable.pdf
- Greg
Kicking It Up.zip
- Greg
great, thanks Greg!!
I will check those out
last night I used a mono 1/4" jack, running the Left channel out into the Ext-in, to get voyager feedback overdrive for the first time
but wanted to keep using both L/R outputs for audio
