Good morning
I am having an issue with the Voyager Electric Blue Edition.
With the following setting:
- "MODULATION BUSSES / MOD. WHEEL"
- "SOURCE TRIANGLE"
- "DESTINATION PITCH"
- "SHAPING PRESSURE"
When the keys amount and modulation wheel have value 0 the modulation is in its maximum they are not off. However, when the value goes over 0 in any control the modulation disappears.
I cannot find a service here and due to the place where i live it is
impossible for me to take it.
I do not have any pedal connected to the back panel.
Does it make the differenced if you connect a pedal with polarity -5v? I do not know if anybody has done it yet.
Ehen disconnecting the pedal ... do the parametres get normal?
Can you help me?
Thanks in advance
Problem Minimoog Voyager Mod Wheel / Amount
Re: Problem Minimoog Voyager Mod Wheel / Amount
Sorry,
but this is by Moog design.
All pots are ranging from -5 to +5 Volts CV output.
And the aftertouch is handled like a pot
Sequence:
Sequence:
Sorry, I do not understand. Before it worked perfect, not today.
