Hello!,
I just bought a used Voyager RME and discovered that the OSC 2 on / off switch doesnt seem to work. Its status (on/off) is correctly updated at the LCD display, but the OSC 2 is allways active. Even with the "INIT PARAMETERS" sound the OSC 2 is on. I only can mute OSC 2 by turning its volume down.
Any ideas? Am I doing something wrong? Is this a hardware fault?
Thanks for any help!
Best
jdoe
Voyager RME - OSC 2 on/off switch problem
Re: Voyager RME - OSC 2 on/off switch problem
It sounds like a hardware issue. You might see if you can turn it off via midi - CC 83.
Thanks, I'm afraid you're right.
CC 83 is not responding. CC 82 & CC 84 are doing their job. Since I'm still able to controll the osc with the level poti, its not a big deal. Hope that I not discover more hidden "surprises". Otherwise I have to find a service point in Germany. (if it is possible to repair a old RME at all..)
