Page 1 of 2
Model D Reissue Noise Level
Posted: Wed Aug 23, 2017 12:49 pm
by Gladmarr
I am the proud owner of a slightly used reissue Model D. It's in great shape and everything seems to work properly except the noise generator. I have no experience with the Model D reissue or original, so this might be normal. The noise volume (pink or white) is nowhere near the volume level of the oscillators, and it seems like it should be higher. Does anyone know if this is normal or if I have a problem? Thanks!
Re: Model D Reissue Noise Level
Posted: Wed Aug 23, 2017 5:50 pm
by till
The noise of my 2017 Minimoog is lower in volume than on my 1979 Minimoog.
Posted: Wed Aug 23, 2017 9:12 pm
by Gladmarr
till wrote:The noise of my 2017 Minimoog is lower in volume than on my 1979 Minimoog.
Is it low enough to be a problem? I'm not sure if mine is a "problem" just yet. I might open it up and see if something is wrong (if it's possible to SEE if something is wrong).....
Posted: Thu Aug 24, 2017 4:20 am
by till
For me it is only a problem, that some sounds need to have different mixer settings compared to my 1979 Minimoog and a friends vintage Minimoogs. And the red noise modulation is slightly lower in max modulation amount. This is a minor problem, but well noticeable if you do an A-B comparison with vintage Minimoogs.
So all in all it is just a minor thing.
But maybe your noise is even lower than my noise level.
Posted: Thu Aug 24, 2017 3:28 pm
by Gladmarr
I did get a private message stating that "the noise level is supposed to be about the same volume as 1 oscillator set to triangle wave with nothing else enabled in mixer section...."
This is basically true with mine, so maybe I'm just nuts. In looking into this, I did notice that the external input normaling to the output for overdriving the filter is NOT working, so maybe there still is a problem. I think I might have to contact MOOG for this one.
Posted: Thu Aug 24, 2017 6:44 pm
by captainkidd
I think the low noise level was brought up in the past and that someone from Moog said that was normal (at least for the Reissue). I do concur that it does seem to be on the low side and it would have been a little nicer if it ran with a bit more higher gains. But overall so far it hasn't been to big of an issue for me that is.
Posted: Fri Aug 25, 2017 12:35 pm
by Gladmarr
Currently discussing both issues with Adam from Moog. Very quick to respond. Hopefully they'll either have a fix or put my mind at ease that there is no actual problem at all.
Posted: Sun Sep 03, 2017 4:45 am
by black_label
I noticed that my noise level (on my 2017) is a lot lower than the oscillator volume and not really great for making those swooshy, noise-based patches like on my Sub37. Glad I'm not crazy at least, though I'd love it if it had an even noise level.
Posted: Sun Sep 03, 2017 8:28 pm
by MC
On the vintage ones there's a trimpot for adjusting the noise level, it is on the power supply board, lower left. No idea if it is the same location on the reissue.
Posted: Mon Sep 04, 2017 4:33 am
by till
MC wrote:On the vintage ones there's a trimpot for adjusting the noise level, it is on the power supply board, lower left. No idea if it is the same location on the reissue.
As there is due to the external PSU for sure not the same power supply board, it is relocated. But finding a transistor with an open leg and trace the ciruits to find a trimmer should be possible. But of cause, this means opening the Minimoog and maybe undue a board or two to get there.
Posted: Mon Sep 04, 2017 8:33 am
by _ADSR_
I concur completely.
The Noise is too quiet. Try recording a slow-rise wind swell and the signal to noise ratio reveals hissing/static louder than the noise.
As soon as a hack is revealed I'll be implementing.
Not the end of the world or anything but it is too quiet.
Posted: Mon Sep 04, 2017 5:16 pm
by ummagumma
interesting, ideally there would be a trim pot somewhere to adjust the noise level
Posted: Sat Sep 09, 2017 1:03 am
by Gladmarr
Small update on my Model D: the noise level doesn't seem to be as much of an issue as I originally thought, but the output looped back to the external input bit is apparently. I got an RMA and I'm sending it back to the Moog mothership next week. Hopefully all will be well after it comes back.
Posted: Tue Dec 05, 2017 3:24 am
by normhart
Don’t know about the reissue but on my 1977, it’s (noise level) one of the three trim pots on the power supply board on the right edge of that board when facing from behind. The other two are the + and - 10v pots.
Posted: Tue Dec 05, 2017 8:40 pm
by Gladmarr
As it turns out.....
