Converting a 10V gate to a 5V gate
John Di Stefano
Post by John Di Stefano » Tue Dec 20, 2016 10:23 pm
Does anyone know of a device I can use to convert a Korg SQ-1 10V output gate to a 5V input gate on the Voyager?
stiiiiiiive
Re: Converting a 10V gate to a 5V gate
Post by stiiiiiiive » Wed Dec 21, 2016 8:41 am
I guess any attenuator will. including the ones on the CP-251 ;)
weary
Post by weary » Wed Dec 21, 2016 3:59 pm
John Di Stefano wrote:Does anyone know of a device I can use to convert a Korg SQ-1 10V output gate to a 5V input gate on the Voyager?
What? KORG SQ-1 V/Oct supported for 5V!
Just hold FUNCTION button on SQ-1 and press 5V buttons on A section and B section (they will light red) to select 5V CV range for each.
You don't need any converters to use SQ-1 with your Voyager. Only patch cables with 3'5 to 6'3 jacks.
Voyager PE, VX-351, 2xCP-251, LittlePhatty SE II, MF-101, MF-102, MF-103, MF-104M, MF-105M, MF-107, MF-108M
John Di Stefano
Post by John Di Stefano » Thu Dec 22, 2016 10:16 am
Perhaps I should ask if anyone knows a CHEAP way to reduce a 10V gate from a Korg SQ-1 sequencer to trigger a Voyager, which is looking for a 5V trigger. I`m told that the 10 volts is too hot for the Voyager. Don`t want to damage this wonderful machine.
sunny pedaal
Post by sunny pedaal » Fri Dec 23, 2016 9:48 am
used it last week from a friend, no problem with the voyager
otherwise ( when not wanting to take "the risk") indeed use a pot or a resistor( very cheap ) in between
captainkidd
Post by captainkidd » Fri Dec 23, 2016 12:34 pm
Well the gate itself according to the manual is 10V, the adjustment here is just for the CV output. I also have some concerns with the 10V gate over the long term.
This also holds true with the Beatstep Pro.
