Can incorrectly using CV cause damage?
machopatty
Post by machopatty » Sat Jun 18, 2016 9:00 pm
I've been using a VX-352, a Slim Phatty with CV outputs to control my Voyager RME. New to control voltage and not knowing how everything should be connected, do I run the risk of permanently damaging the Voyager if I connect something wrong or turn up an attenuator too far?
c7sus
Re: Can incorrectly using CV cause damage?
Post by c7sus » Sun Jun 19, 2016 1:42 pm
Not combining CV's in mults is probably the single-biggest no-no. Use the mixer on a CP-251 or similar device for that function.
bichuelo
Post by bichuelo » Thu Jun 23, 2016 8:54 pm
c7sus wrote:Not combining CV's in mults is probably the single-biggest no-no. Use the mixer on a CP-251 or similar device for that function.
Can you please explain this to us further?
http://audiotecna.info
HookedOnSonics
Post by HookedOnSonics » Thu Jun 23, 2016 9:34 pm
Hi c7sus, i also would like to please ask you to further explain the CV to Mults no no. Thanks in advance!!!
Moog One - A Synth War Story, Synth Wars - The Rise of the Korg Apr2600, Model D, Vintage 2016, Voyager of Sinbad XL, Theremin+, FoogerFamilyOfSix, 3MothersLikeNoOthers, Kronos II - InstantKarma'sGonnaGetYou, Hooked a Full Size KARP, Naboo Royal MiniTaur, White H9s, Criklon, ElektronRytmAvenueMKII
jsharpphoto
Post by jsharpphoto » Fri Jun 24, 2016 1:29 pm
Mults aren't mixers. 1 input, multiple outputs. If you need to mix two inputs, use a mixer.
Moog Format Modular
Model D (2016)
Moog Subsequent37
Oberheim OB-6
Sequential Rev2
