Inserting a guitar effect pedal
Newmoog
Post by Newmoog » Sat Apr 16, 2016 3:00 am
Are there any impedance issues in connecting a guitar effect pedal to the insert plug of a Voyager?
Do I need to use a reamp box for that?
stiiiiiiive
Re: Inserting a guitar effect pedal
Post by stiiiiiiive » Sat Apr 16, 2016 9:34 am
I've done this the simplest way before, no problem for me :)
Newmoog
Post by Newmoog » Sat Apr 16, 2016 1:47 pm
stiiiiiiive wrote:I've done this the simplest way before, no problem for me :)
Thanks, I was planning to get an overdrive. Any suggestions welcome!
stiiiiiiive
Post by stiiiiiiive » Sat Apr 16, 2016 6:55 pm
I must have tried a POG2 for even more octaves :)
jsharpphoto
Post by jsharpphoto » Sat Apr 16, 2016 10:18 pm
Try a BBE Sonic Stomp then into a EHX Bass Muff Deluxe.
Moog Format Modular
Model D (2016)
Moog Subsequent37
Oberheim OB-6
Sequential Rev2
Stevie Ray
Post by Stevie Ray » Mon Apr 18, 2016 1:03 pm
Depends on the particular effects pedal but I have connected all kinds of pedals (including some very old and weird ones) via the FX insert on my Voyager and they have all worked - some better than others. It's a lot of fun. Do check that the pedal is working properly first though.
NickGrooves
Post by NickGrooves » Fri Aug 05, 2016 5:24 am
So thrilled to read this. I was wondering the same thing when I looked in the manual and read about the FX send/return jacks.
Related question, has anyone tried plugging a Mother-32 into that FX loop? This could essentially turn the Voyager into a sequencer. Problems with impedance or voltage?
Of course there would need to be adapters for the difference in jack size (going into M32 ... the output is 1/4" TRS)
Voyager select
Mother-32
Hammond XK-3c
Emu Proteus 2000
ProTools
GregAE
Post by GregAE » Fri Aug 05, 2016 7:19 am
From KnobTweak, two articles related to the use of guitar effect pedals with the Voyager:
‘Secret Weapon’ (see below) – Using an exciter with the Voyager.
‘Kicking It Up A Notch’ – Overdrive techniques using pedals.
Both articles are ZIP files that include mp3 examples. To download, look in the Voyager section under Files:
KT > Files > Voyager
- Greg
NickGrooves
Post by NickGrooves » Sat Aug 06, 2016 2:54 pm
Awesome. I have a rack version of an Aural Exciter, will try it. Maybe post an A/B video if I can find the time.
Voyager select
Mother-32
Hammond XK-3c
Emu Proteus 2000
ProTools
Stevie Ray
Post by Stevie Ray » Tue Aug 09, 2016 6:05 pm
NickGrooves wrote:So thrilled to read this. I was wondering the same thing when I looked in the manual and read about the FX send/return jacks.
Yes I have patched a Mother 32 into a Voyager Old School. The CV tracking leaves a lot to be desired on the VOS.
