Page 2 of 2
Re: Disable save preset with double click the master
Posted: Thu Dec 25, 2014 7:44 pm
by RL
slirak wrote:Is there any updated documentation for the new features?
Unfortunately not yet (maybe Greg has time for it
If there's anything unclear ask here in the forum.
One tip: the programmable CURSOR is undefined on all old presets and there's a hidden function in the MASTER menu "Copyright Info" to reset the CURSOR function in the actual preset bank.
To reset it press MASTER then select "Copyright Info" (page 5.1), press ENTER, then press the +1 button, select "Global Cursor" (page 3.1), then select "Yes" by the CURSOR and press ENTER.
You have to do this for all preset banks separately.
Have fun,
Rudi
Posted: Fri Dec 26, 2014 6:18 pm
by kamilof
RL wrote:If there's anything unclear ask here in the forum.
Have fun,
Rudi
Is there a way to change banks via midi by only using the bank select MSB (cc0) or just bank select LSB (cc32)? Since bank select MSB is always "0", it would be useful to change banks by sending only a LSB or LSB message (7 bits) from my sequencer, instead of the combination of both (14 bits).
Posted: Fri Dec 26, 2014 6:25 pm
by slirak
Hi Rudi,
Well, after browsing through the menus, the only things I wonder about are the Global Cursor and No Boot System settings What do they do/how would you use them? Also, since there are some "hidden" functions, I wonder if there are hidden functions I've not yet discovered. Any chance of a list of hidden functions and how to get to them?
Regards
/Jonas
Posted: Sat Dec 27, 2014 3:24 pm
by RL
Hi Jonas,
the Global Cursor is active for all presets without any own cursor settings (Global Cursor Mode = ON).
When you need a special setting for the cursor you can select it in the EDIT menu (page 6.2).
For example:
the Global Cursor is "Recall last Edit"
for all presets with cursor setting "Global Cursor Mode = ON" the "Recall last Edit" is active
if there is a preset with the cursor setting "MIDI Input" this setting is active
The "No Boot System" function starts the operating system without the boot system. This is very useful when the power breaks in life situations. The operating system starts immediately after power on.
@kamilof
Sorry, the bank controller is a defined controller and I don't want to change that cause many problems can occur.
Posted: Sat Dec 27, 2014 7:30 pm
by kamilof
RL wrote:
@kamilof
Thanks Rudi. Found out that by changing the "Midi Enables -> Bank Select" to receive only CC 32 (see screen shot) I can change banks from my sequencer by only sending CC 32!
Posted: Sat Dec 27, 2014 7:37 pm
by RL
Hi kamilof,
kamilof wrote:Found out that by changing the "Midi Enables -> Bank Select" to receive only CC 32 (see screen shot) I can change banks from my sequencer by only sending CC 32!
OK, when it is now fine for you I can stop thinking about
BTW, you can also select the controllers in that menu by the external input pot.
Have fun,
Rudi
Posted: Sun Aug 09, 2015 2:02 pm
by M-Prod
RL wrote:Hi all,
@M-Prod:
I made a change in the MASTER Storage Mode(s) menu, now you can switch on/off this function.
Had not checked this thread for a while and saw this fix... so better late then never... let me say THANK YOU!!
Posted: Mon Feb 28, 2022 5:19 pm
by oli@sub37
Just found this thread while looking for something completely different. I had no idea that there were more recent Voyager OS releases after 3.5.
What is the reason that 7 years later the officially provided version on the Moog website is still 3.5? Has this 3.6 any issues? Are there other advantages over 3.5 than the mentioned new features?
Posted: Tue Mar 01, 2022 5:31 pm
by oli@sub37
OK, after some digging I found this thread:
What happened to OS 3.6
Where the more recent developments are discussed and
latest versions are linked.
Posted: Thu Mar 10, 2022 12:07 pm
by baw22
Hello, I wonder if someone can tell me where on my laptop is the best/correct place to locate the syses files for uploading? I'm in the main window of MIDI-OX but I can't work out where I load the file for uploading to my Voyager. It doesn't help that I am pretty new to Windows (usually a Mac guy) and everything's quite a bit different.
If it's appropriate, the connection to the Voyager seems to be working fine, as I am seeing Midi activity in the Monitor - Output window,
Many thanks,
Ben
