Voyager tuning: OSC1 range not sufficient
Re: Voyager tuning: OSC1 range not sufficient
Apparently this tuning method wasnt the problem. My tech has been using other guidelines for tuning and those were correct. I used a paper version for the process and it was ok as well. The Moog tunes just fine and everything else seems to work despite that the range trim pot ran out of adjustment before the high E was reached. All the other OSC's tuned just fine. Weird problem. I hope that this change of pots and the resistor is a permanent fix.
