Any experiences with the Thon hardcase?
MBlom
Post by MBlom » Mon Jul 08, 2013 11:12 pm
The ATA hardcase costs three times more than the Thon hardcase. I thought the former would be lighter but it isn't, and I was amazed that they both weigh so much. 9-12 kg is quite a lot extra weight for a case. So why pay more for the ATA? The wheels?
http://www.sweetwater.com/store/detail/VoyagerCase
http://www.thomann.de/gb/thon_keyboardc ... ger_ed.htm
Latest gigs
https://youtu.be/Fpvi7Jrq8DQ
http://youtu.be/owdKlBrUUKY
Minimoog Voyager EB & Minitaur + MF-101 + MF-103 + MF-104M + MF-107 + CP-251 + Minifooger Drive. MachineDrum UW + MonoMachine + Rickenbackerbass (-75) + Hagströmguitar (-75).
ColorForm2113
Re: Any experiences with the Thon hardcase?
Post by ColorForm2113 » Tue Jul 09, 2013 12:53 am
I have the voyager case from moog and I'm glad I did. The wheels and dolly arm are a godsend, that sob is heavy! But I have a similar case to the thomann for my micromoog and it has protected it quite well for a few years
stiiiiiiive
Post by stiiiiiiive » Tue Jul 09, 2013 3:56 am
The Thon seems less solid, doesn't it? I think I would rush on it if it had the same wheels and arm as the Moog ATA case. I don't see myself carrying 25kg by arms...
ColorForm2113
Post by ColorForm2113 » Tue Jul 09, 2013 7:38 am
The coffee house I play at from time to time has 4 sets of stairs, the first two were ok carrying, the next two definitely needed to use the wheels
stiiiiiiive
Post by stiiiiiiive » Tue Jul 09, 2013 8:01 am
The place I live in is on the third floor. Caramba!
Thanks for the concrete info :)
MC
Post by MC » Tue Jul 09, 2013 9:53 am
I will never buy another polymer case. Yes they are lightweight, but they warp when exposed to heat and sunlight.
The Thon reminded me of a similar case I used to own. The non-recessed latches got banged up to the point they no longer worked. And the ball corners broke away from the corners. And that foam lining is too thin, there is a risk of banging the Voyager cases against the metal extrusion and damaging the wood.
The Thon may be 3x the price but trust me I have been enough cases that I keep coming back to Anvil Cases. They may be expensive but you get what you pay for.
drcarver
Post by drcarver » Tue Jul 09, 2013 4:48 pm
I got one bundled with my Voyager. Been using it for a couple of years now. After a few gigs, and many trips back and forth to studios, it is still going strong. The handle and wheels are particularly sturdy IMO.
New album available!
http://www.cdbaby.com/cd/chriscarver
Jay944
Post by Jay944 » Wed Jul 10, 2013 8:17 am
xxxxxxxxxxxxxxxxxxxxxxxx
thealien666
Post by thealien666 » Wed Jul 10, 2013 10:52 am
The Thon seems really cheaply made. Not enough padding inside to adequately protect the wood finish of the synth (especially in the back where all the weight of the synth will crush it when carried), weak hinges, locks and handle. The side of that case will bulge (where the handle is) under the weight of the Voyager after only a few moves.
Not worth the money IMHO.
