Matriarch Arppeggiator stopping on triggers in FW/BW repeat off setting
borisaurus
Post by borisaurus » Fri Jan 13, 2023 5:58 pm
I found a pretty frustrating issue when playing the arpeggiator while the FW/BW repeat parameter is set to OFF. The arp will just randomly stop on a lot of the triggers, and sometimes even have a hard time turning on again. This can definitely be a performance killer!
I document the bug in this video: https://youtu.be/tFHU_7sUgW0
Has anyone else run into this problem? Can anyone replicate it?
ritual_of_the_sea
Re: Matriarch Arppeggiator stopping on triggers in FW/BW repeat off setting
Post by ritual_of_the_sea » Fri Feb 03, 2023 9:03 pm
Hey, just so you know, I was able to recreate your issue with my Matriarch. ORD and FW/BW with Repeat ON were fine, it was only an issue with FW/BW Repeat OFF.
I'm having an issue with the sequencer myself. Perhaps the arp/seq code needs an overhaul...?
