I'm having trouble getting the Matriarch to change the settings of
1.8 Local Control (Arp/Seq) and
2.5 Sequence Keyboard Control
I'm quite familiar with using the Global settings, and to double check it was working at all, I was able to change the pitch bend range successfully.
I must have tried 50 time today to get the Matriarch sending the sequence out via MIDI, leaving the internal synth to be played live, to no avail.
Am I doing something wrong or is this a known bug?
Darren
Global settings issues - Local Control & Sequence Keyboard control
Re: Global settings issues - Local Control & Sequence Keyboard control
Not sure if this helps, but I had to also turn 2.3 Arp/Seq MIDI Output to ON to get the MIDI notes from the Arp/Seq to go out through MIDI. The default is ON, but I had disabled it in the past. So, with 1.8 OFF, 2.5 OFF and 2.3 ON, you should be able to press PLAY on the Matriarch and the MIDI notes of the Sequence will start going out, and the keyboard can be played independently.
