Noise Delay Cuircuit
lrt75914
Post by lrt75914 » Mon Dec 05, 2022 8:43 pm
Hello Everybody,
Since I have my Matriarch hooked up to an Axe FX I never realized how
noise the delay cuircuit of the Matriarch is. I don't know if that's an
issue with my unit or just the nature of the design.
I was wondering if anyone could confirm that this is indeed normal
or a faulty module. Delay Mix is on max to highlight the issue.
The noise itself, however, is noticable as soo as you crank the mix
up to 9 o'clock.
Patrick
Noisy.mp3.zip
(137.59 KiB) Downloaded 61 times
moogy_j
Re: Noise Delay Cuircuit
Post by moogy_j » Wed Dec 07, 2022 9:53 am
That sounds about right. The analogue delay circuit is a bit noisy. It is most noticeable if you you have the cutoff frequency turned down and the delay mix set high.
John
FuzzyCat Software - Software tools for musicians - www.fuzzy-cat.com
"Chonky" - free global parameter manager software for the Moog Matriarch and Grandmother - www.fuzzy-cat.com/products
