Moog grandmother no work well
FrankFB
Post by FrankFB » Sat Sep 03, 2022 4:36 pm
Hello everyone. I have had a problem with my Grandmother. Everything worked fine yesterday, and today when I turned it on it doesn't work right. The oscillators module does not work, as well as the modulation and arpeggiates. In fact, the only sound that comes out is the self oscillation of the filter. Neither the glide nor the hold, play and tap buttons work. Not that this could happen
TangerineDream
Re: Moog grandmother no work well
Post by TangerineDream » Sun Sep 04, 2022 10:53 am
Have you tried resetting it in the global settings?
Achim
Post by Achim » Mon Sep 05, 2022 5:16 pm
I would guess, the Local Control is disabled in the global settings. See the V1.1.3 Release Notes, parameter 0.10 Local On/Off.
This may happen if you connect the GM via MIDI to a DAW.
Matriarch, Grandmother, DFAM, iMS-20, TRM-402
stiiiiiiive
Post by stiiiiiiive » Tue Sep 06, 2022 4:12 am
I wonder... I don't have any GM here but I'm not sure this is the root cause: whether it is the oscillator signal or the filer self oscillation, you must open the envelope to let it through the VCA (Local on/off setting should be tested though).
To FrankFB, what do you mean by this?
FrankFB wrote: Sat Sep 03, 2022 4:36 pm the only sound that comes out is the self oscillation of the filter.
