Matriarch USB MIDI Synch in Ableton problems
memhpis1212
Post by memhpis1212 » Mon Jul 25, 2022 9:56 pm
Hi, my matriarch will not properly sync with my Ableton clock via usb. I have the settings right in Ableton and the two are engaging with one another but the timing is just way off and acts really weird. The arp and delay really makes no sense when it's engaged with Ableton. It's really random and stutters a lot and doesn't work properly at all. Is there anything I can be missing/doing wrong? Again, I'm confident everything is setup properly in Ableton and I can't seem to find what the issue may be as all my other analog gear is working just fine. Any help would be appreciated. Thanks.
thereminist84
Re: Matriarch USB MIDI Synch in Ableton problems
Post by thereminist84 » Thu Sep 29, 2022 9:37 am
Hi there,
you might want to check and follow this Forum post:
viewtopic.php?f=19&t=35577&sid=4954361a ... 32720b03e8
Many people having the same Matriarch Midi Clock Sync issues.
