Mod wheel out on back wrong impedance
andy-cytomic
Post by andy-cytomic » Fri Jun 17, 2022 8:16 am
I noticed the mod wheel output from the back of the synth cannot be used as one of the things connected to a mult to mix it along with any of the other modulation sources, eg the output of an attenuator, or the output of an LFO etc.
Anyone from Moog: is there a specific reason for this? Why make all the front panel mod sources have the same output impedance so they can be mixed with a passive mult but then not also match the mod wheel output at the back to this same level?
MRNUTTY
Re: Mod wheel out on back wrong impedance
Post by MRNUTTY » Mon Jun 20, 2022 7:11 am
not that it needs saying to an impedance complainer :0) but you could make a patch cable with a 1k series resistor.
btw which synth is this for?
2xMother 32, DFAM, Subharmonicon;
