I have an ACL Sinfionion sending 4 pitch inputs to my Matriarch and upon chord changes it sends a gate, which I have patched into the envelopes. When the attack is fast (at zero), it works totally as expected. The second I slow the attack down, even a tiny bit the volume of the signal is reduced to almost nothing.
I've recorded a video showing the issue using my Mordax Data, so you can see what's going on.
https://www.dropbox.com/s/ucb88qi4qwswn ... M.mov?dl=0
Is anyone else experiencing this or have a fix?
I should mention that the slow attack works completely fine if I'm just using the keyboard.
