In the Matriarch I'm often hearing a very quick single or sometimes double click from the LFOs when they get to certain points on any waveform they're set to (the on/off point, it seems) except sine, when they're modulating the PWM of a Pulse or Square wave or LIN FM. Other analog synths I've used/tried didn't do this, as a point of comparison.
Is there a way to eliminate the click? I might be making a noob mistake -- it makes using the LFO for modulating those things unusable, so I hope I am. It happens with either patching from either of the LFO sections into an oscillator or only using the dials in the first modulation/LFO section.
