Matriarch plays two semitones lower than pressed
Mikhail13
Post by Mikhail13 » Thu Jul 08, 2021 3:08 am
Hello everybody! Maybe someone faced such a problem - when you press the note C, the matriarch plays A# and so on. Each note you press on the keyboard is actually two semitones lower (all default oscillator settings). Thank you
moogy_j
Re: Matriarch plays two semitones lower than pressed
Post by moogy_j » Sat Jul 10, 2021 6:44 pm
I haven't seen this problem. Have you checked to see if you have accidently bumped the master tune knob in the back of the unit?
John
FuzzyCat Software - Software tools for musicians - www.fuzzy-cat.com
"Chonky" - free global parameter manager software for the Moog Matriarch and Grandmother - www.fuzzy-cat.com/products
jonmanness
Post by jonmanness » Sat Sep 04, 2021 2:25 pm
Did you resolve your issue? I'm having the same problem with mine.
ringmod
Post by ringmod » Thu Apr 06, 2023 3:31 am
Hi, my Matriarch has also started behaving like this after the 1.3 update. Any luck on a resolution?
One really weird behavior is if I wiggle the fine tune knob it wil correct it self back to C for a second before jumping back down to A#
