Grandmother Dark constant background note
kinomood
Post by kinomood » Sat Nov 07, 2020 9:03 am
Hi!
I'm new here because I've bought a brand new Grandmother Dark.
I'll explain my perplexity: with volume pot set to zero, my GM always emits sound. A very low signal, but clearly audible.
Regardless of the long or short decay! The sound remain in background.
The problem don't exist if I put the headphones, but I think that depend from different impedance.
Even my DAW record the sound. It seems that the volume pot didn't cut the output signal completely.
So my question is: It's a physiological appearance for a Grandmother?
Someone know this issue/problem/bug/characteristic? :roll:
I've just execute the pot calibration procedure and a complete Osc calibration... but nothing!
Thanks all!
dct
Re: Grandmother Dark constant background note
Post by dct » Tue Nov 10, 2020 12:34 pm
Having tried several analog synths (orlder and newer) over the past years, I realized this seems to be a common issue in analog heaven. Long time I thought this is a problem of my old cheap mixer board. But no: If I listen carefully, my GM has exactly the same problem.
It doesn't really bother me, because normally my dB on jamming are far more than this faint sound.
keys: CX-3 II, GRANDMOTHER, streichfett, ZEN DELAY
Sugar
Post by Sugar » Tue Nov 10, 2020 2:29 pm
Are you sure that the sound you've been hearing is not an electrical hum?
kinomood
Post by kinomood » Wed Nov 11, 2020 10:12 am
dct wrote: Tue Nov 10, 2020 12:34 pm Having tried several analog synths (orlder and newer) over the past years, I realized this seems to be a common issue in analog heaven. Long time I thought this is a problem of my old cheap mixer board. But no: If I listen carefully, my GM has exactly the same problem.
Thanks for your impressions. Surely all analog instruments (guitars, etc.) presents bleeds through the circuits.
And I think that could be the same physiological "issue" of GM.
kinomood
Post by kinomood » Wed Nov 11, 2020 10:14 am
Sugar wrote: Tue Nov 10, 2020 2:29 pm Are you sure that the sound you've been hearing is not an electrical hum?
Yes, I'm sure. No electrical hum from any Usb or sockets. Just tried!
Ted H
Post by Ted H » Fri Jan 15, 2021 7:25 pm
I just heard this on my Grandmother also. But if I use headphones instead of running to my mixer, no noise. Doesn't sound like that's a GM issue, though no other instrument running to my mixer (Behringer Xenyx), has any underlying noise. Tried a different TS cable with no remedy.
Sugar
Post by Sugar » Wed Jan 27, 2021 3:22 am
google "ground loop noise"
David P.
Post by David P. » Sun Nov 07, 2021 7:49 pm
I have this too. I sent mine back because of this. Then got another one with the same problem but worse, first one had that noise coming from osc 1 only, the second GM had that in both oscillators. It is the same problem and the same as you explained it to us. Plus when I turn my GM on you hear a small blurp of sound when it's powering on.
David P.
Post by David P. » Sun Nov 07, 2021 7:51 pm
It's like this, if you hit a high note on the keyboard then the noise sounds high pitch, if you hit a low then low pitch. That's the emitted background noise characteristics explained.
David P.
Post by David P. » Mon May 23, 2022 11:44 am
Just to follow up. I ended up solving this, and it is associated with a ground loop issue, the solution for me was to change from a Furman power strip which it was plugged into and plug it into the wall directly. Solved. Also a different power supply which Moog sends you solves it. It is a 2 prong instead of the standard power supply which comes with the GM. Contact Moog, explain your problem and they'll offer a replacement power supply. D
