New Matriarch Global Settings Editor
mreid
Post by mreid » Fri Oct 09, 2020 5:33 am
Hi everyone,
Thanks to the new v1.2 firmware update that enables global setting editing over SysEx, I was able to build a simple Matriarch settings editor that runs in your browser using a JavaScript MIDI library.
You can try it out here: https://mreid.github.io/matriarch-editor/index.html
There are instructions on how to use it on the same page as the editor.
I hope some of you find it useful.
Jobinho
Re: New Matriarch Global Settings Editor
Post by Jobinho » Fri Oct 09, 2020 6:58 pm
Thanks for taking the time to create this, I know a lot of us will be very grateful!
Markyboard
Post by Markyboard » Sat Oct 10, 2020 7:57 am
Fantastic! I was concerned at first that it wouldn't work with my DAW (Reaper) open at the same time. But it's just a matter of disabling the Matriarch track so that it can recognize the USB or midi ports . I guess it's not multi-client? Not a big deal as this is so much better than manually configuring the globals. If someone comes up with a VST version that would be even better. Until then I'll be using this.
Thanks and well done!
hudri
Post by hudri » Sun Oct 11, 2020 3:56 am
Hi, looks good!
You do also know about my standalone program MatriarchSwitch?
mreid
Post by mreid » Sun Oct 11, 2020 8:40 pm
Hi hudri,
No, I hadn't seen that. Looks great!
Being able to save settings is a really useful feature. And the parameter descriptions are nice too. I'm hoping to add similar things to the one I wrote when I next get a chance.
Regards,
Mark
hellleutel
Post by hellleutel » Mon Oct 12, 2020 3:02 pm
Hello! First post! :)
This looks so great.
I'm on a Mac with Mojave and I can't get it to run with neither Firefox or Safari, although I've installed the API extension... it always says "MIDI-Out: Cannot find Matriarch! MIDI-In: Cannot find Matriarch!"
Before I try much further, has anyone succeeded with this configuration?
mreid
Post by mreid » Tue Oct 13, 2020 4:20 pm
Can you try Chrome? I found it to be the simplest browser to set up for this. No plug ins required, it just pops up a prompt asking for access to your machine’s MIDI ports.
Also, maybe check that the MIDI ports for your Matriarch have the word “Matriarch” in them. The editor currently assumes that. You can check the name using the Audio MIDI Setup app on your Mac.
bichuelo
Post by bichuelo » Tue Oct 13, 2020 8:00 pm
For me, it works on macOS High Sierra on Firefox, Chrome and Opera.
Only the latter loads the defaults from the synth, and Firefox is the only one which doesn't bring a pop-up asking for permission to use MIDI ports
http://audiotecna.info
MrBlue
Post by MrBlue » Wed Oct 14, 2020 2:06 pm
Works with the Brave browser... :wink:
La musique c'est de l'émotion en suspension dans l'espace et le temps - un ami d'Albert !
illustrasons
hellleutel
Post by hellleutel » Wed Oct 14, 2020 8:03 pm
aaah yessss using Chrome seems to do the trick thanks a lot
