Hi all, I updated the Mother-32 yesterday and everything went smoothly. The new features all sound great, but now when I try and record in Ableton using a MIDI clock, the notes from the Mother-32 are playing slightly out of sync. I've also noticed they aren't playing evenly, with no swing applied.
Has anyone else encountered this before?
Mother 32 - Clock out of sync after updating
Re: Mother 32 - Clock out of sync after updating
I've had the same issue on version Firmware version 2.0 + the assignable output also not clocking out correctly,l I've gone through extensive troubleshooting and have been in touch with Moog support and they were able to reproduce this and has been forwarded to engineering. Should be getting a fix in the next firmware update. If you really need to have it clock through the M-32 you can downgrade the firmware to get the old behavior back.StellarChaos wrote: ↑Mon May 11, 2020 8:27 pm Hi all, I updated the Mother-32 yesterday and everything went smoothly. The new features all sound great, but now when I try and record in Ableton using a MIDI clock, the notes from the Mother-32 are playing slightly out of sync. I've also noticed they aren't playing evenly, with no swing applied.
