Matriarch Issues
Tabletop Semi-Modular Analog Synthesizers
Deva
Matriarch Issues
Post by Deva » Tue Sep 10, 2019 12:13 am
Hi Peeps...
Had a Matriarch for 4 days now. I'm so loving this synth! Incredible sounds!
I do have a couple issues.
First, if I plug cables into the second Attenuator, then the first Attenuator controls filter cutoff (no cables in the first Attenuator at all). Weird issue... check a number of times and turned the synth off and back on and the issue is unchanged.
Second, if I plug in a sustain pedal and hold the pedal down and play a series of notes, only some of the notes trigger.
_DemonDan_
Re: Matriarch Issues
Post by _DemonDan_ » Wed Sep 11, 2019 11:39 am
If I plug cables into the second Attenuator, then the first Attenuator controls filter cutoff (no cables in the first Attenuator at all). Weird issue... check a number of times and turned the synth off and back on and the issue is unchanged.
I don't have one in front of me, but I recall that there's a default behavior that passes the output of Attenuator 1 into Attenuator 2 if there's nothing connected to the Input of Attenuator 2.
_DemonDan_
Post by _DemonDan_ » Wed Sep 11, 2019 11:42 am
If I plug in a sustain pedal and hold the pedal down and play a series of notes, only some of the notes trigger.
I think that may have to do with which Voice Mode you're using, and what Note Priority type is chosen.
Deva
Post by Deva » Fri Sep 13, 2019 2:13 pm
It is default which is last note played... notes should play every time
Deva
Post by Deva » Fri Sep 13, 2019 2:18 pm
Yes... It is working as it should... just it was unexpected
Deva
Post by Deva » Fri Sep 13, 2019 2:23 pm
I've had an issue where I use the Tap Tempo for the Arp/Seq and then when I turn it off, the speed of the Arp/Seq is too fast until I turn it off and back on.
penguinrock
Post by penguinrock » Tue Sep 17, 2019 9:54 am
Sustain pedal.
I'm not 100% sure about duophonic and paraphonic modes, but in monophonic mode, the sustain pedal will returns to the first note played upon release.
For example, if I'm playing a G note, press down and hold on the sustain pedal, then release my finger (sustain pedal is working), then play A, B, etc. (sustain pedal is holding each note I play as I go along), then release the sustain pedal... The VCA will play its release cycle on that first G note.
I read in a Facebook group where someone found a similar issue in paraphonic and duophonic modes.
Perhaps there can be a firmware fix for this so that the VCA releases on the last note played upon release of the sustain pedal.
