I need your help to control my M32 on my Subsequent 37CV via CV in order to use M32 as a 3rd osciallator on the other synth. Basically, I wanna do the following:
https://www.youtube.com/watch?v=OxBRxgqIEr0 :
However, I cannot trigger M32 on the Sub37 CV but I am only getting a crankling and regularly flapping noise of which the tempo could be changed by frequency knob of the M32.
Please see below my setup:
- M32 VCO1/Oct to Sub37CV CV Out1 (KB Pitch) using a TS 3,5/6.3 cable
- M32 VCA Mode is On
- M32 line out to Subs37 CV line in using a TRS 6.3/6.3 cable (or M32 GateIN to Sub37CV Gate Out1 (KB Gate) using a TS 3,5/6.3 cable // or M32's VCO Saw/VCO to Subseq37CV EXT in)
- Subsequent 37 CV Ext. in is turned on / Latch is on
I am under an impression that I should cablibrate the VCO on the M32 to get the Subseq 37CV tracking the M32 but it sounds a little bit complicated and I do not dare to jump into calibration.
I was also trying the pretty similar setup with an Arturia Keystep and it is working fine.
How to connect Subsequent 37 CV with Mother-32 via CV connec
Re: How to connect Subsequent 37 CV with Mother-32 via CV connec
Hi E.P.,
your described setup seems to be the correct way to use the M32 as a third oscillator.
Perhaps we have (had?) the same problem because I can't get ANY cv-signal out of my subsequent 37cv. Have you been able to use the Sub37 cv-voltage/gate for any other purpose before?
cheers!
david
cheers!
david
Anyone ever figure it out?
