Grandmother sequencer retrig/reinitiate sequence or not?
knifeedge
Post by knifeedge » Tue Jul 30, 2019 3:21 am
Hi everyone! New here.
I have a question about the Grandmother.
Situation: sequencer running in hold.
If you press a key to transpose the sequence, does this only transpose letting the sequence continue (please make it so), or it also restart the sequence from the first step?
Thank you!!
Andrea
knifeedge
Re: Grandmother sequencer retrig/reinitiate sequence or not?
Post by knifeedge » Mon Aug 05, 2019 10:20 am
Anyone? :idea:
ummagumma
Post by ummagumma » Tue Aug 06, 2019 5:44 pm
I just tested mine, it restarts the seq from the beginning when you press a key
however, this may be adjustable: have you read the manual?
*edit* I just had a look through, and it doesn't appear to be adjustable in the global settings
knifeedge
Post by knifeedge » Wed Aug 14, 2019 4:59 am
ummagumma wrote:I just tested mine, it restarts the seq from the beginning when you press a key
Thank you Ummagumma!
I also contacted the Moog technical support and it seems that for now the behaviour I desire is far from be implemented. Anyway, I solved in two ways:
- use the sequencer of a Keystep
- sending a toggle sustain pedal midi message (cc64) while GM seq is in PLAY mode only (no hold)
