Grandmother note drift.
Posted: Sun Jun 30, 2019 6:03 pm
by IAmSoundengine
Hey everyone. First post and its regarding my first Moog.
I bought the Grandmother in January, so I've had it for a few months now, but today I noticed when I turned it on and would play a note that just after I would let go of the note the tuning would drift flat about 10-15 cents during the release portion of the envelope. Otherwise it stays relatively in tune during an single note press or long drone.
I will say that the heat today is particularly hot(90-degrees F), and it is the first time I've encountered this at all. It is affecting both oscillators. I already ran through the tuning cycle just a minute ago to no help.
There are no patch cables plugged in, everything is zeroed out or off with the exception of the minimum required to generate a tone.
Any ideas? Or is this just one of those nature-of-the-beast kind of things?
Thank you in advance.
Re: Grandmother note drift.
Posted: Tue Jul 02, 2019 3:26 pm
by ummagumma
hmm, to see if it is heat related, you could try running a fan into/onto it for a while, and see if it has any effect?
*edit* well I see there are no vents on the thing!
maybe leave it in front of your A/C
Posted: Thu Jul 04, 2019 10:42 am
by IAmSoundengine
I obviously cycled the power switch once or twice and that didn’t do anything, but when I physically unplugged the power cable from the back and plugged it back in it *seems* to have solved the issue for now. Perhaps there is a ground fault somewhere in my system. :?:
