Moog Music Forum
Share Ideas and Pass the word
Grandmother how to step advance
Tabletop Semi-Modular Analog Synthesizers
Postby tektile » Wed Apr 03, 2019 2:05 am
I'm trying to get the external clock "step advance" mode to work on the Grandmother. I've set it to ignore external midi clock, and set the global setting for external clock input to "G0" (step advance). I am sending an irregular trigger pattern into the clock input from a TR8s, but it still keeps on running continuously.
I can clearly hear the sequencer being influenced by it, because its BPM now fluctuates. It seems like it is treating my trigger signal as a constant clock from which to derive the BPM.
Also my trigger signal should be solid. It's coming from a dedicated trigger output on the TR8s.
Did anyone get this feature to work?
tektile
Re: Grandmother how to step advance
Postby tektile » Thu Apr 04, 2019 2:31 am
This is indeed a bug, and will be solved in an upcoming firmware update.
tektile
Return to Grandmother, Mother-32 & DFAM
Who is online
