Moog Music Forum
Share Ideas and Pass the word
Grandmother: How to sync modulation rate?
Tabletop Semi-Modular Analog Synthesizers
Postby Mooger90125 » Sat Jan 19, 2019 11:11 pm
On the Grandmother, how do I sync the modulation rate EITHER to:
1) DAW clock (I'm using Logic X)
2) Arp/seq rate (I can sync this to Logic, so being able to sync modulation rate to this would also solve my problem)
Thank you!
Mooger90125
Re: Grandmother: How to sync modulation rate?
Postby robotecho » Sun Feb 03, 2019 1:00 am
I've had a good look, I don't think you can. "Rate in" matches the LFO frequency to the control volatage frequency, not a clock signal. So it's most obvious use is syncing the LFO frequency to the keyboard frequency to use as an oscillator.
"Sync" syncs the start of the LFO cycle to the trigger, not the Frequency of the LFO.
Moog Grandmother (Firmware 1.0.2) | Arturia Keylab 61 mk II Controller | Win 10 64bit, Core i7 3.6GHz, 32GB RAM | Studio One 3 | NI Komplete 11 | Focusrite Scarlett 18i20
robotecho
Postby Ted H » Sun Mar 03, 2019 8:58 pm
I just tried several ways to have "Rate In" to Modulation clock with the Arp/Seq, which is being clocked externally. Even tried "Clock Out" on the rear panel patched to the "Rate In", and got some weird noises (feedback?) when the mod wheel was used. Mainly trying to have the S/H rate = Arp rate. Any other suggestions?
Ted H
Postby Suspish » Mon Mar 04, 2019 4:55 pm
I think this might achieve what you are trying to do, but haven't tested.
-Set the rate of the S/H slower than the ARP rate
-Patch KB Gate out to LFO Sync in
When the gate retriggers the LFO, it should grab a new sample and hold value, but that is where I am not entirely sure. If it does, it will change with each note of the arpeggiator, as long as the LFO rate is slower.
Suspish
Postby Ted H » Wed Mar 06, 2019 5:55 pm
While triggering the mod rate from the KB-Gate-out does start a new S/H note, the actual mod rate isn't affected. That I can tell.
Ted H
Postby robotecho » Sat Apr 06, 2019 4:54 am
It is possible I am going mad, but I was working on a patch two nights ago with the arpeggiator synced to my DAW, and I had a long rising and falling filter sweep on the LFO. I noticed it was holding time over two bars, and thought, "oh thats lucky", then I listened for a few minutes and it held time perfectly.
Is there a chance the LFO syncs automatically when the arp light goes green? I haven't had a chance to test it properly, but it wouldn't surprise me too much.
robotecho
Postby bichuelo » Sun Apr 07, 2019 11:17 pm
Thats exactly how it works, you can check the details on page 27 of the manual
http://audiotecna.info
bichuelo
Return to Grandmother, Mother-32 & DFAM
Who is online
